20 Most Recent
Minolta bizhub 180 Black and White Copier Questions & Answers
Reset error m2 in konica minolta 164
Replace the drum and developer first. Resetting counters with out replacing parts is not good. The machine works on base on counter info you reset counters then not replace parts the copier will adjust voltages on certain items when in fact they are same items image problems and codes. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
CAUTION MAINTENANCE CALL (M2) CALL SERVICE
Replace the developer and drum/cleaning blade. Also reset the counters after replacing parts then run F8. resetting the counter with out replacing the above items cause image problems. The copier uses the counters to determine voltages on the drum you tell the copier drum is new and it is still old will cause problems. Btw, I’m available to help over the phone in case u need at
Maintenance M2 call service
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.1-Press utility button on panel.2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.3-its the code to get into service mode.4-After pressing above mentioned buttons you will enter into service mode.5-Now select service choice option.select it by pressing OK button.6-In service choice option you will see Maintenance count option.7-Select it by pressing Yes or OK button.8-There will be three options 0,1,2.9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
MAINTANANCE M2 MINOLTA BIZHUB 163
Need to have the drum and developer and cleaning blade replaced, then have that M2 counter reset. Resetting the counter with out replacing the drum developer and cleaning blade will cause codes and image problems. Machine uses the counters to determine voltages for certain assy. If you clear the counter and not replace the parts the machine adjust voltages for the drum and developer assuming it new when in reality it is old. Btw, I’m available to help over the phone in case u need at
Maintenancecall 2
First it indicates that the drum needs to be replace along with developer. has that been done? Then who did it for got to clear the counter. Go to service mode Utility then stop 00 stop 01 . Then to # 9 Clear counter then to supplies life counter clear yes exit out Btw, I’m available to help over the phone in case u need at
C220 error code& solution
C0210
Abnormal image transfer voltage
- The image transfer voltage remains more than 100 V continuously for a given period of time while the PC Drum remains stationary.
Bizhub 164 m2
Press the Utility button,
then Stop 0 0 Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
Which are very important for copy quality, and not replacing them may cause more harm than good.
Kode m2 bizhub 184
press the Utility button,
M2 call service for 211
Konica minolta 164 maintanance call m2 error solutions
Bizhub 164 maintanance call m2 solutions iam neede
Konica Minolta bizhub 164 m2
Bizub 164 maintanence m2 code remove
