I need directions to remove and replace the maintop (cooktop) of my black frigidaire self cleaning oven!
I can find the replacement part but no directions on how to install!
Help please!
To remove the main top first remove the grates,
burner caps and burners. Using a ¼” socket
wrench or nut driver remove the mounting
screws at each burner orifice assembly.
Insert a putty knife or similar tool between the
main top and manifold panel near the outside
of the front corner. Push the putty knife toward
the rear to release the maintop mounting clip.
Repeat for both sides.
When the mounting clips are released the front
edge of the cooktop can be lifted. Make sure
that the orifice assembly does not bind in the
cooktop when raising the top to remove it from
the range.
Lift the front of the cooktop and pull forward to
disengage the back edge from the rear hinge
bracket. The cooktop can now be replaced by
reversing the previous steps.
See Manual at
http://www.electroluxtopservicelatam.com/image/Manuals/Services%20Manuals/Preparation/Cooking/30%20Inch%20Freestanding%20Gas%20Ranges%20(5995440277).pdf
Hello Larry D Harris - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
