20 Most Recent
Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black Questions & Answers
Frigidaire electric stove
Hello friend, thank you for your post!
If you had an over spill in the back of your Frigidaire oven it could have possibly shorted out the terminal block or control panel. I would recommend cleaning any access spill and contacting a professional to come out and verify no additional internal damage has been done to the appliance. I hope this is helpful. -Matt
FFES3025LSA F10 ERROR
Hi Friend, this is Z. Thank you for your post!
Typically error code F10 indicates that your Frigidaire range (FFES3025LSA) has detected an issue with the runaway temperature (overheating). Let's attempt reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is best to wait roughly ten minutes and then turn on your range. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps!
I went to clean my oven last night but my oven
HELLO,
HERE ARE SOLUTIONS ON HOW TO CLEAN THE OVEN OUR SELF
self cleaning solution
1 Remove oven racks and soak them in soapy water
2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
3 Let the oven do its work; it will heat for several hours, charring off baked-on food.
Fast Cleaning method
1 Remove oven racks and place them in soapy water to soak.
2 Preheat oven to 200 degrees.
3 Turn the oven off and spray the inside with oven cleaner.
4 Allow to sit for 10 minutes.
5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently. 6 Dry with a soft cloth
hope this solution help?
Thanks.
F93 eror
What is the complete model number of your
unit?
What is vari broil
please, help my kenmore stove is older and i have tried may times to broil and have trouble..i turn on the vari broiler and it doesnt go on..what am i doing wrong??
Frigidaire electric range model FFES3025LSa
I have had the same problem. A repairmant has been out twice. I had an F30 code aalso which I believe is a temp sensor. However he replaced that and had to replace the control assembly to repair it. I have had it go out twice while under warranty and it just went out again. If you have a buzzing I would replace the control assembly.
Model no. REG435LR-2 has F2 and F3 displayed when
Hi
Error F2 and F3 error means a loose/broken wire on the oven temp sensor or the sensor is bad and should be replaced. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...please post back for further assistance.
Daniel
