20 Most Recent Frigidaire FEF366 Electric Kitchen Range Questions & Answers
How can I take my frigidaire gas range out of demo mode
Frigidaire... | Answered on May 08, 2019
there is more to it than just replacing the glass .
and I'm not aware of any kits that allow this .
Frigidaire... | Answered on Feb 12, 2015
Hi Carol Moore, thanks for your inquiry!
From the information you have provided you need assistance using the self-clean feature on your Frigidaire range. Here are some basic steps to starting your self-clean:
1. Remove the racks within your oven.
2. Press Clean.
3. Use the "Up" or "Down" arrows to pick a three or two hour cycle.
4. You should then see a "CLn" on the panel. The door will lock and cleaning will begin.
I hope this information is helpful. -Matt
Frigidaire... | Answered on Dec 10, 2014
Good Afternoon Friend,
I understand that you have scratches on the ceramic stove top of your Frigidaire rage, model# FEF366. Small scratches do not affect cooking and will become less visible with time. To prevent any further scratches, make sure you do not use any abrasive cleaners. These can scratch your stove top even more. Try not to use cookware with rough bottoms. These can mark or scratch the cooktop surface. Try not sliding any metal or glass across your cooktop. This includes sliding your pans as well. Coarse particles such as salt or sand between cooktop and utensils can cause scratches. Be sure your cooktop surface and bottoms of utensils are clean before usage. I hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jun 27, 2014
www.buyspares.co.uk/cookshop-spares/shop.pl
Try above or here.
www.salterusa.com/salter_us/contacts
Frigidaire... | Answered on Jun 16, 2014
Hello Paul, this is Z. Thank you for your inquiry!
If you are receiving an error code F11 on your Frigidaire range, it typically indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to your appliance. You can do this by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree.
Frigidaire... | Answered on Jun 04, 2014
Email me at jubileebethel76@gmail.com send me a picture just to help me get my brain around it and a phone number and I will be able to help you out more efficently
Frigidaire... | Answered on May 22, 2014
disconnect power, pull off back panel check paperwork for fuse location if that is not broken then a simple solution I found to work on other display screens for my parents oven was to take the circuit boards ribbons(parallel lines for coding to pass through like an old school computer and simply remove and re attach this most of the time can solve this type of issue just be careful not to damage anything else). if you have any questions just ask.
Frigidaire... | Answered on May 16, 2014
Hi thanks for the question. lay the door on the floor .the hinge must be locked before it can be installed back in the oven. each hinge has a locking clip . push down on the hinge and lock with clip . same on the other side. install door. push door down. unlock the clips. close door. to remove door. push door down. lock clips . pull oven door out . thanks the appliance doc
Frigidaire... | Answered on Mar 19, 2014
if range is self clean make sure door is closed, put on self clean wait about 0ne minute or so then cancel self clean . sounds like range is stuck in door lock Cheers
Frigidaire... | Answered on Dec 12, 2013
Start the self clean and then move the bar over so it will lock and complete the self clean cycle.
Frigidaire... | Answered on Nov 28, 2013
The pop was a shorted wire.
The short drew sudden over-amp at breaker.
Amps = heat.
Breaker senses heat and trips before wire to oven is damaged, and before the arcing short can cause a fire.
Was the short at the element?
I don't know, but sounds like the circuit board was damaged.
Of course they are putting electronics inside all appliances today instead of old mechanical dial, because it's cheaper or so much prettier... but new appliances more vulnerable to surge, and other electrical failures. Which is true for all 240V appliances not protected by whole house surge protector.
To test element.
Remove element.
Use a continuity tester across the element connections.
If there is continuity, then the element is probably functional.
Use a multimeter across same element, set multimeter to read ohms.
240 Volt, 3500 watt element should be about 16 ohms.
4500 watt about 12-13 ohms
Volts squared divided by watts = ohms
57,600 divided by 4500 watt = 12.8 ohms
http://waterheatertimer.org/images/ohm-reading-for-emements.jpg
http://waterheatertimer.org/See-inside-main-breaker-box.html
I would guess that the short fried the circuit board, but there is a also a shorted wire somewhere that is still bare and dangerous while power is ON and you are touching oven or stove, unless 240V breaker is GFCI or arc fault, which probably not. Especially dangerous if you are moving stuff around trying to find problem while power is ON.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Frigidaire... | Answered on Nov 19, 2013
Frigidaire FEF366 Electric Kitchen Range Logo
276 questions posted
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Kitchen Ranges
Most Popular Question
frigidaire not heat consistently f10
  • Kitchen Ranges
