20 Most Recent Frigidaire FEF352 Electric Kitchen Range Questions & Answers
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@$#%@#$%
Frigidaire... | Answered on Nov 26, 2015
Good Afternoon Friend,
I understand you want to know how to replace the EOC in your Frigidaire range, model# FEF352. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to replace the EOC with ease. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jul 10, 2014
Good Morning Kathy, this is Z. Thank you for allowing me to assist you!
If you are receiving an error code F10, it typically indicates that your Frigidaire range (FEF352) has detected an issue with the runaway temperature (overheating). Let's try reprogramming your range by either unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. I suggest waiting approximately ten minutes and then turn on your range. If the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (Electronic Oven Control) will need replacing. Hopes this help!
Frigidaire... | Answered on Apr 01, 2014
Good Afternoon J, this is Z. I'm happy to assist you!
If you are getting an error code F2, it usually means that your range is experiencing a communication failure between the EOC (Electronic Oven Control) and ESEC (Electronic Surface Element Control) system. I would recommend, however, running a quick test to ensure that this is not a false error code. You do this by resetting your oven by flipping the breaker or unplugging it for approximately ten minutes. If resetting your range does not correct the issue, please reach out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Frigidaire... | Answered on Mar 12, 2014
Look for a button or sensor which turns the light off or which the door would press when closed.
If you find it hold it down for a minute, then let go this should reset the lock
Frigidaire... | Answered on Nov 14, 2013
I tried pressing clean then the up arrow. Nothing. THEN I HELD DOWN THE UP ARROW FOR A FEW SECONDS AND 3 HOURS CAME UP AND it worked and my oven is now cleaning itself. Remember...HOLD DOWN the up arrow for a few seconds and it will work
Frigidaire... | Answered on May 01, 2013
Hello Scott Gerken - I understand you are seeking instructions on how to clean your oven. I have located the manual on the manufacturer website. Hope you find all the data that you need and let me know if you need further assistance.
Frigidaire... | Answered on Mar 26, 2013
What exactly is your concern with the unit? How is it not working?
Frigidaire... | Answered on Dec 31, 2012
Sounds like a connection issue to the control panel and the lower portion of the unit. Contact a professional to have the unit diagnosed unless you find the ohm reading to be off for either broil or bake element.
Frigidaire... | Answered on Dec 26, 2012
Hello parmantal - Typically error code F31 indicates that the unit has a shorted probe connection problem. Try resetting the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and this will usually clear most false codes. If it proves to be ineffective, contact a professional to move forward accurately. The technician will need to check the resistance and/or harness between the EOC and probe connector. Depending on the diagnoses part(s) will need replacing.
Frigidaire... | Answered on Dec 20, 2012
Hello - I would first suggest confirming that the range is plug to the proper voltage (120/240 Volts 40/50 Amp). Was there anything located behind the range before pushing it back? From what you have described it sounds like the control board will need diagnosing. Contact a professional to move forward accurately.
Frigidaire... | Answered on Oct 24, 2012
Hi - Typically error code F3 indicates a faulty sensor probe or wiring harness between sensor probe and EOC. Try resetting the range by unplugging it or flipping the circuit breaker off for two minutes (this usually will clear most false error codes). Turn on the range and if resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Frigidaire... | Answered on Oct 23, 2012
Sounds like the element or the control board to the element is not communicating correctly. I would have a professional diagnose the element first. You may only need to replace it. Otherwise it could be the control board not allowing the element to heat up properly.
Frigidaire... | Answered on Sep 11, 2012
Frigidaire FEF352 Electric Kitchen Range Logo
Popular Tags
159 questions posted
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Kitchen Ranges
Most Popular Question
getting f10 oven
  • Kitchen Ranges
