One For All URC-3300 Remote Control Logo
FRANCES HEIMS Posted on Jun 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Adjusta-magic control for my Englander bed will not work. HELP PLEASE! The foot of the bed will not go down.
The serial number on the bed is D2460. The the model number is 005628F76U. The ADJUSTA MAGIC IS THE SIGNATURE SERIES.
ernesto cuadra
Level 3:
Top Expert:
  • One For All Master 12,223 Answers
  • Posted on Jun 14, 2012
ernesto cuadra
One For All Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4081415
Points
34431
1) You must open the foot of the bed , and see for the switch, and test it with a VOM, see for open , tight any wires loose cables, or broken and repair. God bless you
My Adjusta-magic control for my Englander bed will - 6_14_2012_7_48_37_pm.gif
2answers
Tempur-pedic TEB-100 remote works with foot of bed up and down but bed head is down but will not raise up. Help
please try to use the remote from a different position of your bed. And also please test the remote when you're not lying on the bed to see if the upper portion will change. If not, please reference the troubleshooting section of your manual next.
Thank you.
I have a simmons nuflex bed that is fine except the foot wont raise. Massage works on foot, but it just wont lift. No clicking or noises when using the remote
If the foot of your Simmons Nuflex bed will not raise, there may be an issue with the motor or the lift mechanism. Here are a few things you can try to fix the problem:
  1. Check the remote control: Make sure the remote is properly functioning and the batteries are not dead. Also, check that the foot lift button is not stuck.
  2. Check the wiring: Check the wiring between the remote, the lift mechanism, and the motor for any frayed or disconnected wires. If you find any damaged wires, they will need to be repaired or replaced.
  3. Check the lift mechanism: Inspect the lift mechanism and look for any visible damage or debris that may be preventing the foot from raising. Clean the lift mechanism and lubricate it with light oil.
  4. Check the motor: If the motor is not functioning properly, it may be preventing the foot from raising. If the motor is faulty, it will need to be replaced.
If you are not comfortable with these steps, or if the issue persists after trying them, it may be best to contact Simmons customer support or a professional technician for further assistance. They may ask you to provide your bed's serial number and other information to help troubleshoot the problem.
Sep 07, 2022 • Furniture
2helpful
2answers
Bed foot is stuck in the up position
Try resetting the remote control and control box also check batteries
Which side of bed is considered " right side?"
the right side is at foot of the bed taken that way , just as cars, when you look at them from the front it was motor's maual that confirmed this fact for me years ago, hope this help.
Jan 31, 2015 • Home
No problem,we recieced this stove serial # whi005277 englander is the from a friend.he had no manual with it anymore and we have no idea on how to use some of the parts that are on it.it looks to be ...
Unfortunately, the Serial Number of the wood stove is not much help. However, the Model # would be. It should either the Model Name or Number somewhere on the stove.
5helpful
2answers
RS-25 foot pedal not working
The foot pedal needs to be plugged in before the software is installed. Just uninstall the software (your files will be fine) and reinstall with foot pedal attached.
26helpful
6answers
Foot switch will not respond.
The answer is all in the serial number you use to install the DSS player!
Look carefully and you will see the recorder disk has in my case an [E] printed above the install serial number and the transcription pedal has [T]
Install the same disk with the E the driver is there, the control in Control Panel is there, but the foot switch does not work with the software. Put in the serial number with the [T] and foot switch works first time!
If you uninstall the play and then reinstall with the [T] serial number you do not need to reboot or even unplug the foot switch from the USB.
Bingo
Top One For All Televison & Video Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
