20 Most Recent One For All URC-3021 Remote Control Questions & Answers
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
One For All... | Answered on Nov 15, 2018
it is DIS5619A9 worked for me-
D I S A in numbers
3 4 7 2
345561929!
One For All... | Answered on Oct 22, 2018
Here are some of the various Sharp TV codes
SHARP 0093, 121, 121, 064, 065, 081, 322, 122, 185
SHARP 002, 013, 014, 111, 502, 712, 812, 813, 913, 918
SHARP 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 0813
The 081 code worked with my LC-37SB24U
One For All... | Answered on Sep 25, 2018
Tengo un vcr magnabox y un TV Mitsubishi
Me puedes ayudar ?
One For All... | Answered on Aug 10, 2017
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
One For All... | Answered on Jul 05, 2017
The codes are, 0145,1145,...Step 1. Turn the TV on. 2. Press the TV button. 3. Press and hold the SET button until the LED blinks twice, then release. 4. Enter one of the four digit codes, the LED will blink twice. 5. Aim the remote at the TV and press the POWER button, if your remote does not have a power button, press PLAY, the TV should turn off, if not, try steps 1-5 again using a different code....hope this was helpful...
One For All... | Answered on Jun 18, 2017
How about an on-line manual? Click here to download an owner's manual for thomson ROC1407 in pdf format. Read it thoroughly and you will find all the required instructions.
Note: click here if you are unable to download. This link will take you to the download page.
One For All... | Answered on Mar 29, 2017
Hi
You can obtain the User's Manual with code list from the link below
http://www.expressfix.net/manuals/remotes/URC-3220
One For All... | Answered on Jan 31, 2017
I can help you with your URC-3021 Universal Remote Control issues.
You can find the One For All URC-3021 Manual here.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
_______________________________________________
One For All URC-3021 Code List
One For All URC-3021 Code Search
One For All URC-3021 Reassign Key
Without knowing what brand of TV you would like to control, may I recommend using the URC-3021 One For All URC-3021 Code Search, or refer you to the Urc-3021 Code List?
I hope that helps.
Reassign URC-3021 Device Key
Urc-3021 Code List Download
Programming Notes
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
One For All... | Answered on Oct 18, 2016
Check this codes 0184, 0209, 1479, 0479 for Orion TV.
Other codes see in the URC 3021 owner's manual at this link One For All URC 3021
One For All... | Answered on Oct 15, 2016
Magnavox 0054, 0706, 0030, 1454, 1254
your code.
then release SET.
CH, or PLAY).
first.
blink twice.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
One For All... | Answered on Oct 04, 2016
Try procedure to program remote without code.. Look manual how to do it, it's different doe each remote
One For All... | Answered on Sep 10, 2016
One For All URC-3021 Remote Control Logo
1,929 questions posted
Top One For All Televison & Video Experts
Steve Allison
Steve Allison
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • One For All Televison & Video
Most Popular Question
set up remote
  • Televison & Video
