20 Most Recent Magic Chef 31000 Gas Kitchen Range Questions & Answers
My roomate took the oven racks out to clean ...Now
Usually the racks are shaped so they won't pull out accidentally. The back side has an upward tilt and catches on the sides of the oven to lock the rack in. What you need to tilt the rack up so you can slide the back edge in first. Then you can tip it back down to its normal position and slide it back the rest of the way.
Hope this helps. If so, please take a moment to rate my solution. Thanks for asking here!
11/24/2020 5:41:04 PM • Magic Chef 31000... • Answered on Nov 24, 2020
I want to convert my magic chef kitchen stove..model number, 31001saw from gas to propane..how much is the conversion kit and a good site to buy it from..?
There's not much difference except in the pressures of the gasses. The PROPANE must have a round attachment that controls the pressure of the gas, is inline, usually close to the tank. On the top of that device, valve, is a screw-type mechanism, often covered by a flat piece of plastic that can be gently pried off. If you research, you'll find how much to turn that set screw, and in what direction. It's quite easy.
12/8/2015 4:39:11 PM • Magic Chef 31000... • Answered on Dec 08, 2015
Searching for plastic push on control knobs
Hello.
I search it however, not to find the replacement parts, in this case i would rather suggest you to contact the vendor of your kleenheat, maybe they know where to find the service center of that machine or their tech maybe can cater the problem.
mlenavz
11/19/2015 7:15:04 AM • Magic Chef 31000... • Answered on Nov 19, 2015
The electric igniters for the stove burners stopped working. All four stopped at the same time.
If all 4 stopped working at the same time, the problem is with the spark modulator. If the igniter is working on several of the burners but not on another, (or any variation), the problem is with the igniter wiring harness. By design, the igniter for each burner is daisy chained in the wiring harness such that if one goes, the others will still work.
3/24/2015 2:28:26 AM • Magic Chef 31000... • Answered on Mar 24, 2015
Oven goes in lock mode.
unfortunately it sounds like you need a new board
12/20/2014 9:00:56 PM • Magic Chef 31000... • Answered on Dec 20, 2014
My magic chef gas range stop clicking and how to replace the igniter
If you life up the top of your stove, the igniter should be just on the right side at the front - mine is far right. Mine went and I did not replace it, but now use a bic bbq lighter to start it instead. Just as easy and I do not have to put up with that annoying click-click. lol. You should be able to buy your replacement part at an appliance dealer, whether household or RV.
12/10/2014 8:34:12 PM • Magic Chef 31000... • Answered on Dec 10, 2014
0answers
Oven will shut on and off constantly
Sometimes the hot surface ignitors are fine, but they do not have enough draw to start the gas valve. If the oven doesn't light I would replace those first
1/17/2014 11:13:14 PM • Magic Chef 31000... • Answered on Jan 17, 2014
0answers
Light pilot
Be the first to answer 11/14/2013 11:03:19 PM • Magic Chef 31000... • Posted on Nov 14, 2013Be the first to answer
Magic Chef 31000 Gas Kitchen Range Logo
311 questions posted
Top Magic Chef Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Magic Chef Kitchen Ranges
Most Popular Question
cannot find replace battery in chef
  • Kitchen Ranges
