20 Most Recent
One For All URC-3300 Remote Control Questions & Answers
Comment utilise urc3300b03
Direct Code Entry
- Press and hold the SETUP button until the red indicator stays on, then
release the SETUP button.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator
blinks, then stays lit.
- Enter the 4 digit code from the code tables. Note: after a valid code entry,
the red indicator turns off. For an invalid code, the red indicator flashes.
- With your device on, press CHANNEL UP. If the device responds, no further
programming is required. Note: If some buttons do not operate your device, try
one of the other codes for your brand.
Code SearchIf after trying "Direct Code Entry" your device does not respond, or if your
brand is not listed, try doing a search of the code library for your code by
following these steps.
- Manually turn on the device (TV, VCR, etc.) to be controlled.
blinks once, then stays on.
- Press the CHANNEL UP button repeatedly (up to 300 times) until the device to
be controlled changes channel. The red indicator blinks, then stays lit.
- Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes
under CBL, etc. If you want to store a VCR code under CBL, etc., first follow
the procedure for Direct Code Entry and press CBL in step 2 of Direct Code
Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search.
I have a one for
needs the codes for a one for all big esay remote urc-3300b03
an emerson tv
