20 Most Recent Olympus AS-2300 PC Transcription Kit Questions & Answers
2answers
HOW TO INSTALL OLYMPUS DRIVER FOR FOOTSWITCH RS24
Hello your foot pedal don't need drivers but you need for sure a transcription software, the pedal will required a program to work together to control your audio files for example you can get a Olympus transcription software that will be compatible with your pedal, at http://www.tvps.com/Products/Olympus-AS-5002-DSS-Player-Pro-Version-5-Transcription-Software---New__OL-AS-5002.aspx or you also can used http://www.tvps.com/Products/Olympus-AS-7002-Pro-ODMS-R6-Transcription-Software---New__OL-AS-7002.aspx
8/28/2020 3:50:05 PM • Olympus AS-2300... • Answered on Aug 28, 2020
0answers
3answers
Olympus AS-2000 Dictation Kit - Foot switch doesn't work on Vista
HTML clipboard Olympus AS-2000 is not Vista compatible, you need to upgrade your software, I am not sure which version you have, but I think its version 6 ? You need to upgrade your software from version 6 to 7 (free) and then from version 7 to Standard (also free ) . check your foot pedal if it's RS-23 ( check the back of it ) then you need a new foot pedal ( RS-25 or RS-27 ) , if you have the RS-25 or RS27 you are ok .
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1219&os=w
Hope this will help
Joseph
11/12/2012 10:22:12 AM • Olympus AS-2300... • Answered on Nov 12, 2012
Auto Rewind
Try clicking on Tools, then set auto backspace.
8/14/2012 2:35:18 PM • Olympus AS-2300... • Answered on Aug 14, 2012
Auto-rewind
it is digital and does not have auto-rewind.
8/9/2012 7:52:39 PM • Olympus AS-2300... • Answered on Aug 09, 2012
6answers
Foot switch will not respond.
The answer is all in the serial number you use to install the DSS player!
Look carefully and you will see the recorder disk has in my case an [E] printed above the install serial number and the transcription pedal has [T]
Install the same disk with the E the driver is there, the control in Control Panel is there, but the foot switch does not work with the software. Put in the serial number with the [T] and foot switch works first time!
If you uninstall the play and then reinstall with the [T] serial number you do not need to reboot or even unplug the foot switch from the USB.
Bingo
6/24/2012 10:50:23 PM • Olympus AS-2300... • Answered on Jun 24, 2012
I have been using dss
If you have a 64 bit version of Windows 7, you will need an RS27 foot pedal. The RS23 and RS25 are not supported. RS27 is available at dictationmall.com
10/6/2011 6:55:52 PM • Olympus AS-2300... • Answered on Oct 06, 2011
0answers
I am just beginning to
Player light does not work with a foot pedal. You need to get the full version software. Item AS2400 includes the foot pedal, software and headset.
8/2/2011 8:05:54 PM • Olympus AS-2300... • Answered on Aug 02, 2011
How to run AS-2300 software
The AS2300 foot pedal RS23 or RS25 are not compatible with 64 bit operating systems. You will need an RS27 pedal, available at http://www.dictationmall.com/147-035.html
Also the software is not supported on windows 7. You can get a free upgrade to the latest version, dss player standard, here. http://olympusamerica.com/cpg_section/software_results.asp?id=1219&os=w
If you have version 6, you need to upgrade to version 7 first. Once at version 7, you can then upgrade to player Standard.
6/26/2011 2:12:41 PM • Olympus AS-2300... • Answered on Jun 26, 2011
How can I find software
Contact Olympus at 1-888-553-4448.
2/12/2011 3:02:41 AM • Olympus AS-2300... • Answered on Feb 12, 2011
Can one of you clever people help me please? I've
Assumimg that you have version 6 software, you can upgrade your software to v. 7.4.1, this will give you .ds2 compatibility.
Here's a link for upgrades,
1/25/2011 6:10:30 PM • Olympus AS-2300... • Answered on Jan 25, 2011
Can anyone give the serial number of dss player?
83600121000764552812
1/17/2011 11:24:54 PM • Olympus AS-2300... • Answered on Jan 17, 2011
Olympus AS-2300 PC Transcription Kit Logo
47 questions posted
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Olympus Audio Players & Recorders
Most Popular Question
auto rewind
  • Audio Players & Recorders
