I have the Frigidaire FLGB82OODS and it's the same thing...As it turns it squeels and squeeks LOUDLY. It sound's like it needs oil. Imagine a squeaky wheel turning and it's off and on throught the whole cycle (more ON). Any suggestions?I have the Frigidaire FLGB82OODS and it's the same thing...As it turns it squeels and squeeks LOUDLY. It sound's like it needs oil. Imagine a squeaky wheel turning and it's off and on throught the whole cycle (more ON). Any suggestions?
You can't post conmments that contain an email address.
change the high-limit/cycling switch located on the element tubes outside,they get weak from heat and cycle too soon,so element cools frequently during drying
It could be either ... to resolve, pop the top and remove the front. Remove the drum. Inspect the belt. Inspect the wheels. Inspect the front bearing (which is the frame around the door.
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry
Loads dried using the Towels, Heavy Duty, Normal, Perm
Press, and Delicates cycles will dry automatically at the
selected temperature to the desired dryness level. The
dryer uses sensing bars to sense the moisture level of
the load as it tumbles through heated air. Auto Dry
cycles save time and energy and protect fabrics. The
estimated drying time will be displayed for about 5
minutes, then the outside of the display will light up in
a circular track to indicate the drying time is automatically
being determined by the sensors. When the load
has reached the selected dryness level, it will continue
to tumble, unheated, during a Cool Down period. This
helps reduce wrinkling and makes items easier to handle
during unloading. The estimated Cool Down time will be
displayed.
Drying time varies depending on size and dampness of
load and fabric type. If the load is too small or almost
dry, the sensing bars may not detect enough moisture
to continue the cycle and the cycle may end after a few
minutes. Select a Timed Dry setting to dry such loads.
Room temperature and humidity, type of installation and
electrical voltage or gas pressure can also affect drying
time.
For cycle selection turn the knob on the front of the
dryer control panel. The light will illuminate next to
the cycle selected. The following is a brief description
for what cycles should be chosen for certain items and
materials to be dried.
During normal operation, the display may show:
“ad” - dryer is in an auto dry cycle.
“dn” - cycle is done in auto dry.
“PF” - a power failure to the board has occurred.
“Err” - an error has been detected.
“LOC” - control lock is activated.
“PAU” - cycle has been interrupted.
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00 Please let me know if I can assirt you further.
