20 Most Recent Frigidaire GLEQ2152ES Electric Dryer Questions & Answers
I had this same issue. My dryer would run and heat up but then stop and give me the f40. I measured all thermisters and everything was in range. The tech sheet stated that I needed to buy a new control board and I did. Same problem.
The solution was a loose connection on for p4. I took needle nose pliers and squeezed the connector to make it fit tight on the board and everything is working now.
Bottom line, expensive dryer with cheap connectors.
Frigidaire... | Answered on Jul 07, 2018
check venting if ok temp sensor
Frigidaire... | Answered on Sep 11, 2017
You may have a thermal switch defective. This is a switch that reacts when temperature is exceeded. Before you undertake repair do the following steps:This problem may be caused by the dryer air filter that filters the lint excaping the dryer .(1) Remove the dryer air filter, clean the lint from the screen , wash the screen in hot water using dish soap, ( this will remove the Fabric Softner also called Fleecy sheet which deposits an invisible film on the mesh screen that can not be detected so easily) . Once you have done a good cleanig of the air filter screen, reinstall it and operate the dryer....(2).if this has not cured your problem then open the top cover of the dryer (using a kitchen knife to trip the cover clips located at the front ) and you will find the thermal swich located near the top of the door edge. Check it with a meter to check continuity (to check it is closed), if it is opened , replace the thermal switch.
Good luck and good repairs.
Frigidaire... | Answered on Aug 21, 2017
just remove the door front panel....the replacement felt is self sticking..........fix the felt with the join at the top...........
cheers
Frigidaire... | Answered on Jul 30, 2017
No power. The dash is off washer machine frigidaire. Model fffs515pa
Frigidaire... | Answered on May 27, 2016
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Frigidaire... | Answered on Mar 10, 2016
Hey Andy, thank you for your post!
From what you have described your Frigidaire dryer, GLEQ2152ES, is running for a few seconds and then displaying an error code of "PF". The error code of "PF" means there is a power failure and this could be an issue within your control panel or power source. I would suggest performing a reset, this could help clear our any miscommunications within the panel, and you can do this by disconnecting the power cord for at least ten minutes. I hope that this information is helpful towards your repair. -Matt
Frigidaire... | Answered on Feb 26, 2016
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Frigidaire... | Answered on Feb 17, 2016
Thank you for your inquiry, Joe!
I see you would like to remove and replace the control panel on your Frigidaire dryer, GLEQ2152ES. Unfortunately there are no instruction guides on how to remove the panel. I have included a parts schematic for your dryer and I hope that information is helpful for you. -Matt
http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=GLEQ2152ES+&User=&Search=Search
Frigidaire... | Answered on Sep 02, 2015
sound like front felt glide assy # upper felt seal part #134440200 lower felt seal #134134700 u can order these from sears.com
these componets support the front of drum and when felt wears away then clothing slips in gap and when dreyer tumbles clothing gets snagged in gap and tears clothing and leaves black scuffs
Frigidaire... | Answered on Jul 15, 2015
no lights no power means your control board is gone or your machine isnt getting power fromt eh outlet make sure you have power going to the machine
Frigidaire... | Answered on May 06, 2015
they usually just pry up... but I can't guarantee since I don't know what
Frigidaire... | Answered on Apr 25, 2015
how long b4 u can start it agin?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Frigidaire... | Answered on Apr 22, 2015
Sounds like a board communication problem check and spray connections
Frigidaire... | Answered on Feb 19, 2015
maybe full of fluff and needs to be cleneed out
Frigidaire... | Answered on Feb 05, 2015
Hi,First of all check your door switch, make sure it is operational.If the door switch checks good, the start switch could be faulty, in newer dryers the start switch is built into the timer in older dryers your start switch may be separate, if you have to push on the timer dial to start the dryer, its built into the timer.
Check any other safety's that may be stuck open.Double check anyway. If it wont do anything, I would say its the door switch or the start switch.
Thank you
Frigidaire... | Answered on Jan 26, 2015
U MEAN THERMAL SHUT OFF? OR THERMAL CUT OFF? USUALLY NON RESETTABLE
Frigidaire... | Answered on Dec 20, 2014
Frigidaire GLEQ2152ES Electric Dryer Logo
771 questions posted
Top Frigidaire Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Dryers
  • Frigidaire Dryers
Most Popular Question
frigidaire dryer gleq2152es0 counts down
  • Dryers
