20 Most Recent Frigidaire Affinity ATF7000ES Front Load Washer Questions & Answers
What does Frigidaire affinity dryer code E61 mean
E61 is a line voltage problem, most of the time it means you have the neutral and the L2 wire either reversed or in the wrong position. Verify that the voltage is correct at the plug then at the machine and that you have 240 volts at the terminal block on the back of your dryer.
10/10/2016 1:09:27 AM • Frigidaire... • Answered on Oct 10, 2016
Dont know nothning about a code i just know it was working fine now it dont turn on once it came on and about an hour later and washed that load but now nothning
Hey Dale, thank you for your post!
From the information you have provided your Frigidaire washer is not operating properly. This issues you are having could be a possible problem with your control panel or a wiring harness. I would recommend seeking additional assistance from a professional technician for proper diagnosis and repair. This will prevent you from any unnecessary part purchases or improper disassembly of your washer. Good luck! -Matt
1/2/2016 2:38:53 PM • Frigidaire... • Answered on Jan 02, 2016
MI SECADORA ES FRIGIDAIRE AFFINITY MODELO AEQ6000ES2 Y ME DA ERROR E68
confirma que sea realmente el error del boton atorado y si todo esta bien agrega un resistor de pull down al micro eso me funciono en una secadora que arregle
12/13/2015 1:31:56 AM • Frigidaire... • Answered on Dec 13, 2015
My Washer will not always spin at end of cycle, what happened?
Hello. You've got an intermittent problem. In order to troubleshoot this, you will have to read the last stored error code--there are very many codes. In order to read the code, with the washer off, push the start/pause and cancel buttons simultaneously. As long as you hold the buttons, the last stored code will be displayed. The door lock, wash ,rinse, and final spin lights will flash. You will have to either give the error code on this site or look it up--use the model number and error code on a search engine. This problem is hard to diagnose when not onsite--yes, I'm a tech. My gut is telling me the problem is with the motor control board located inside the unit at the bottom on the left side if you face the unit from the rear. But it could also be with the main board--the error code(s) will tell the tale. Things to initially check: (1) drain pump--it won't spin if it can't drain properly. (2) door switch, if it's loose or worn, it might be breaking contact and causing cycle stoppage. (3) does the basket spin very freely with nothing in it?(If a small article of clothing has gotten in-between the basket and tub it can cause a bind). Also, if there is a roaring sound like a train or a jet aircraft taking off during the spin cycle, that is indicative of a bearing failure--a VERY major, costly repair. If you are unsure or hesitant about troubleshooting, definitely call for service--I have worked on a lot of these washers--not that they're bad at all, just complex. I hope I helped you!
8/21/2015 11:15:06 PM • Frigidaire... • Answered on Aug 21, 2015
How to read error codes
Hey Brenda, thank you for your post!
Based off the information you have provided you would like to read the error codes on your Frigidaire washer. What kind of codes is your washer displaying? I was unable to locate a list of codes. If you can provide me with further information I would be able to assist you. -Matt
4/30/2015 5:13:32 PM • Frigidaire... • Answered on Apr 30, 2015
Spin cycle doesn't remove water
pump
4/12/2015 8:06:46 PM • Frigidaire... • Answered on Apr 12, 2015
Water intake valve rubber hose
NOT SURE i UNDERSTAND UR QUESTION?
3/31/2015 10:51:12 PM • Frigidaire... • Answered on Mar 31, 2015
2answers
I am trying to run
Try "Jeans" instead of "Spin".
3/5/2015 10:48:25 PM • Frigidaire... • Answered on Mar 05, 2015
2answers
I can't get the water to spin out of the cylinder.
You can TRY to blow the clog backwards into the washing machine... by packing a "blow" canister vacuum cleaner or a shop vac on "blow". If the pump is clogged, the reverse pressure will force the clog into the washer... and then you can mix it with some water and try to let it go out in the normal way.
The machine must have the water turned off and the machine must be set to the "drain" setting. The pump will clog sometimes (rare) and I have used air pressure to clear them before.
Only other solution that I know if is to lay the empty washer on its face and access the pump from underneath... disconnect the exhaust hose and try to "fish" out the clog.... good luck
2/10/2015 4:20:48 PM • Frigidaire... • Answered on Feb 10, 2015
How do I get a mouse out of my tumble washer? It is living between the metal drum and the interior, accessing the outside via the soap drawer...
Go to a hardware store and buy some sticky pads (glue boards). Place them around the laundry and near were you think the mouse is feeding. Don't stop when you catch one as there is most likely two or three.
1/9/2015 10:26:01 PM • Frigidaire... • Answered on Jan 09, 2015
Why is my washer not starting and continues to go back to pause?????
Thank you for your post, Jeannie. I am happy to assist you! If you are receiving an error code PAUSE, it commonly indicates that the door of your washer is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If these basic troubleshooting tips prove ineffective, try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your washer. If the issue persists, then your washer could possibly have a faulty door latch or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts. Hope this helps!
9/11/2014 3:58:14 PM • Frigidaire... • Answered on Sep 11, 2014
Where is the pressure calibration switch on an affinity front load washer?
Hello garrett_lind, I appreciate your inquiry!
From my understanding you are searching for the pressure calibration switch on your Frigidaire washer due to the fact that it is not spinning on the last cycle. Some possibilities as to why your appliance is not spinning could be your timer or drain pump. I could not locate steps to access the pressure switch but for electrical components I would recommend having a professional come out to properly diagnose and repair the appliance. -Matt
8/13/2014 8:36:46 PM • Frigidaire... • Answered on Aug 13, 2014
Keeps pausing
Hello Friend, this is Z. Thank you for your post! If you are receiving an error code PAUSE, it commonly indicates that the door of your washer is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If these basic troubleshooting tips prove ineffective, try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your washer. If the issue persists, then your washer could possibly have a faulty door latch or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
7/22/2014 1:52:22 PM • Frigidaire... • Answered on Jul 22, 2014
16answers
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
7/14/2014 9:40:02 PM • Frigidaire... • Answered on Jul 14, 2014
Washing Machines Logo
321 questions posted
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
sometimes will not spin out end cycle
  • Washing Machines
