Computers & Internet Logo
Anonymous Posted on Jun 04, 2012
Touch pad not working
My touch pad is not working pls give me a solution
General Systems Consulting
Level 3:
Top Expert:
  • Master 5,051 Answers
  • Posted on Jun 05, 2012
Master
Level 3:
Top Expert:
Answers
5051
Questions
0
Helped
1060841
Points
15385
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Acer Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
1 Related Answer
Anonymous
  • 1383 Answers
  • Posted on Jun 24, 2009
SOURCE: touch pad driver not loading at boot up
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=468789&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%C2%BB
seelct your os and downlaod touchpadd river from here then install.
Hp probook 5520 mouse pad is locked. The keyboard and mouse buttons are working but the touchpad is locked. how do i unlock it?
there would be a small button right beside the touch pad LED. press the button and LED will turn to white or green and your touch pad is unlocked. pls rate the slolution however you find this....
....thanks...may
2helpful
2answers
My touch pad not working probably, if i press the left most button on the pad the adjacent right button is activated for instance if i press 1 it 2 is getting activated. pls give me a solution for this. i...
That must be a hardware problem. Your touch pad need to be replaced with a new one. If your phone still covered with manufacturer warranty, you can have it repair free of charge. But if not, you can bring it to any phone repair shop to fix it.
29helpful
4answers
Emachines e725 Touchpad Not Working
The eMachines E725 has a built in switch to toggle the touchpad on or off by the touch of a button. Look at the button to the left of the main power switch. You'll notice the icon looks like a hand touching a rectangle - or touchpad. if this button is lit up, the touchpad is turned off. simply press the button to toggle the touchpad back on. The light on the button should now be off.
It's that simple.
Go to device manager
Right click the touchpad device
Uninstall driver
Reboot system
go here http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-66690-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3795289
Reinstall touchpad driver
see if that helps
If you found this solution helpful , please rate my solution below
Kind Regards
1234s282
My touchpad is not working
install the tachped dirver in laptop and
check it ........and 2nd option is remove the touch pad and install new one more info www.compudesk.in
2helpful
2answers
My Dell Inspiron 1525's touch pad is not working properly.
Let's try resinstalling the touchpad software first:
If you're using XP it's HERE
If you're using Vista it's THIS ONE
Let me know if that works.
1helpful
2answers
Touch pad driver.
Uninstall the driver from the device manager, then reboot. The machine will find the touch pad and reinstall the drive automatically. If this doesn't work, check the touch pad connection, they will sometimes work loose ar get a little dirt/corrosion build up. The connection is under the keyboard. At this point, if it's still not working, then it has failed and will need replaced.
1helpful
5answers
LG LP Model LS50 EC6E1
How do I enter setup (BIOS) on my IBM ThinkPad A21e 2655 PC Notebook
Grand Canyon Tech
Grand Canyon Tech
