20 Most Recent
Acer Aspire 3000 Notebook Questions & Answers
DVD player stuck on region 1
If you want to play DVD from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software that allows you to play DVDs from any region. There are several available on the Internet but my favourite is DVD-Region Free From: -
www.dvdidle.com/dvd-region-free.htm
There is no sound on
Do you mean there is no sound only in media player? You hear sounds in other applications? If so then you have probably muted your player. There is a small speaker icon in the player at bottom of the screen. Just click on it once and you will hear sound again.
Sai.
Emachines e725 Touchpad Not Working
The
eMachines E725 has a built in switch to toggle the touchpad on or off
by the touch of a button. Look at the button to the left of the main
power switch. You'll notice the icon looks like a hand touching a
rectangle - or touchpad. if this button is lit up, the touchpad is
turned off. simply press the button to toggle the touchpad back on. The
light on the button should now be off.
It's that simple.
Where can I download windows xp?
Sorry to say,
officially Windows XP is no longer available for download as a trial and moreover, it can not be bought from Microsoft's official store. It is so, just because currently Microsoft has ended it's support partially to Windows XP (SP1 & SP2) and Vista (SP1) and will fully end it's support in the Mid of 2014.To know more, visit,
http://windows.microsoft.com/en-US/windows/help/end-support.If still you are willing to have Windows XP, you have to download it online (which will, of course, be illegal) from torrent sites or something like that.But if you love to buy a copy online, you should visit:
http://erclk.about.com/?zi=5/2rbmBefore you proceed, you may like to read this article:
Where can I download windows XP?.Hope this helps, Mrityunjay.
Emachine E725 touchpad does not work
The eMachines E725 has a built in switch to toggle the touchpad on or off by the touch of a button. Look at the button to the left of the main power switch. You'll notice the icon looks like a hand touching a rectangle - or touchpad. if this button is lit up, the touchpad is turned off. simply press the button to toggle the touchpad back on. The light on the button should now be off.
It's that simple. I hope this helps.
Screen Contrast
On, your keyboard, there is the FN key in blue. hold it and go over to the four arrows pointing. up,down,left and right. the top and bottom arrows is what you use to change your comeputer's contrast.
Adjust screen Contrast
<Fn> +
Contrast up Increases the screen Contrast
<Fn> +
Contrast
down
Decreases the screen Contrast.
This will help you achieve this adjustment.
Need to restore acer to factory settings
just boot from your backup disk. it will guide you to reload the Operating system (factory default).
FYI, if you haven't delete the recovery partition, you can use alt+f10 to reload. just press alt+f10 during boot.
Im trying to reset my acer to factory settings and
In order to reset your computer to factory setting you have to have the system restore disk and put it in your cd drive and reboot your computer with it inside... after pc boots up, a screen should popup click on restore to factory settings... if you dont have a disk reply back and i can give you a link for download..
Display has lines that run through it
they can be horizontal. I think your graphics card on your motherboard is bad. you should consider sending it to acer so they can replace it with a new one.
Graphics card -5011 : 0x80040702 installing error ?
Tell me if i am wrong, but is that french ? And i have not seen a SiS chipset of any kind for the last 9 years, i thought they died about that long ago.
Some manufacturer chipsets were not able to be updated, only by the OEM manufacturer and as such the drivers could not be updated. ( A prime example is the Ferrari 3200 with Ati 128mb gpu only had 1 driver which was created by Acer, tried to update via AMD, but did not recognise the card. The unit is now whats known as "end of service life" and not supported by Acer. As an experiment, have you tried the official drivers from Acer to see if they work ?
The product key I enter
i am not sure what you are trying to ask
so please forgive my stab in the dark
i am assuming that you are trying to install software by entering a product key. this maybe a serial number for the software like windows or some application.
the product key on the bottom of the acer, may not have anything to do with the product key you need to install the software.
that product key may be on the installing dvd, or you may have to ask your dealer for the serial number.
