20 Most Recent
HP Compaq nc6220 Notebook Questions & Answers
When I shut down my computer time and day of the system is disturbed
The RTC coin is dead, batterythree are 2 version of this PC< the 2006 version oldest. is what I will showthe manual at HP.com is there and shows the stepspage 153 of 266 (pdf #)http://h10032.www1.hp.com/ctg/Manual/c00622160.pdf10 steps to get the top cover off and is covered there
Compaq nc6220 PC Notebook: Hi my HP nc6220 is either freezing randomly. Or it...
Well yaeh lol. How long did u have it 4 and how long ago u ckeaned up in side ??? Thers is like a funel tunnel directly from inside of yr Fan Cpu to an outside grill that is ida on yr back (not bottom lol back ) or on left on the side.. u have to look if it not bloked. As if it is. Thats the symptoms u'll be getting all the time u till cleaning it. Also the fan in side collects quiet a lit there 4 making yr fan work extra hard, thats were the noise will be frm, and fron that it cant cool yr cpu on time and cpu's on them are running extrimly hot up to 100% and if thats happening u will get freezes and ramming up.. also since after clean instals u have same problems. I woukd check if u dont have same soft or device that u connect or using and it may be : ida slaging coz u got XP, or incorectly configured ( if it device ) or has wrong dtiver or outdated one, that will pull yr hall system back... but all that can be checked wile it happening, I would recomend installing small soft to monitor real time yr cpu temp, it really small wont use any am hardly but it will show u what is happening wi yr cpu temp than you will know if it worth openning to clean it as it is a bit of job.. and second run task manager to monitor what is pulling yt lapi wen it freezing.. well tjats a start ?? Hope it he,ps you, G/ luck ??.. Tony
HP Compaq nc6220 freezing up problems?
old relic puters. near useless now. what OS? operating systemwhat game, name it>(solitaire?)you cant just sway HDD< the HDD put in alien must be freshloaded with the correct HP windows, disk.2005 is first year madeold that is, here is a black screen page with simple teststest 1 does bios screen work.i bet yesso reload the oS disks from HPsold with windows 2000, XP and Vista.which one you have only you know;http://jeepdied.com/look/puters/dead-screen.html
Set up google home page
when on google page goto tools and then goto internet options click on that,then a window will open just click on use current the click ok.
How do i make google my home page
when you get the google page up,goto the top of the page and look for the word,,tools..tap on it and look right at the bottom and you will see the word,internet options,go in there and you should see a box open saying,,internet options,and in that box you should see,www.google.just below that you should see,,,use current,,click that and it should save the google page.
Battery power
Is the battery charged? Looks like you try to startup the laptop with a discharged battery.
How to make google my homepage
go to right hand side of the page at the top should be a drop down menu find tools scroll down to internet options type on Google and apply this will change ur homepage to google hope this helps x
Make goggle my home page
top right hand side of the page find tools drop down menu go to internet options type in Google and apply then load your home page as normal hope this helps x
