Refrigerators Logo
Anonymous Posted on Sep 23, 2008
I have an 18 cu. ft. Frigidaire that the compressor is running on but the unit isn't getting cold enough. Is there a way to charge the refrigerant?
butch welch
Level 2:
Scholar:
  • Expert 147 Answers
  • Posted on Sep 23, 2008
butch welch
Expert
Level 2:
Scholar:
Answers
147
Questions
0
Helped
89039
Points
373
Odds are great that if you clean the condenser coil (the coil under your frig) and check the Condenser fan to be sure it is running. (little fan under the frig) Bet you its one or the other..*****
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
2answers
13 yr old frigidaire refrigerator has stopped geting cold in freezer and refrigerator
how about the compressor motor still running?.then check the thermostat knob which set to off or get bad.
I have a samsung 1 year old fridge that wont get cold at all. the compressor, evap and condensor fans all run and i installed a schrader valve on low side to try to vacuum and charge with no luck. it
Compressor should rapidly bring pressure down from standing pressure to running pressure when switched on. If no change, compressor not pumping. Make sure the line tap valve isn't leaking, and the gas you used was correctly charged.
My refrigerator isn't staying cold nor is the
Look and see if coils need cleaning below. Do a good clean. Feel the compressor, if it's hot to the touch or cold it may have a bad relay. A relay can fail to drop circuits (causing the compressor to overheat) and open (causing the compressor to be idle).themobilian_2327.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
18 ft frigidaire 5 years old used seasonally fan and compressor run but no cold
thata a close call, if you indeed know that the compressor is running.. should be hot when on..and still no cool in freezer section. sounds like a MAJOR refrigeration issue, requiring sealed system repair.. its close because the manufacturer covers selaed system repairs for 5 yrs. ck your manual and with the manufacture first, because you can replace the unit for cheaper than doing repair out of warrantee,
Motor/compressor hums but does not run. is there a reset button on this unit?
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Refrigerator Is on coldest setting but wont get cold enough, Freezer Is cold and below freezing level but not as cold as It could be. I have unplugged unit over night but it didnt work...
Hi, The refrigeration unit could be low on charge or even over charged..but only gauges will tell that story...and a pro to read them properly...
but...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
heatman101
1helpful
I have an 18 cu ft Crown Frigidaire which is 9 years old. It seems to run too much. I am familier with the dollar bill test on the door seal and have tried it. There is some resistance to the bill but I...
if gasket is seating all around door, and You Food is fairly cold, you probably need some freon the ref. runs longer to make up the temp until unit leaks to low
Freezer and Fridge are both not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
hhsg
Frigidaire freezer, only 2 bottom slelfs freeze
If your freezer is six years old the compressor warranty is also over. Sounds as though the system has lost its refrigerant charge. A refrigerant leak in these smaller units is difficult to locate and somewhat expensive to repair. Your choice.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
