20 Most Recent Nintendo DS Lite Questions & Answers
Nintendo DS Lite, Powers on, Black Screens
Probably overheated and damaged the GPU.
10/29/2022 5:20:43 PM • Nintendo DS Lite • Answered on Oct 29, 2022
5answers
Edge.dat tidak menemukan
'Kay...
I just got that problem too.
"Edge.dat tidak menemukan" means that "Edge.dat cannot be found".
There's a way to fix it.
1) Check your Microsd Card
2) Redownload the EDGE or iEDGE
EDGE: http://www.linfoxdomain.com/nintendo/ds/dl.php/EDGE_OS_v2.0.rar
iEDGE:
http://www.linfoxdomain.com/nintendo/ds/dls/iEDGE_OS_v2.0.rar
3) Then, you will see an books icon, right click and choose "Extract Here".
_15.png 4) When done... you'll have:
_16.png 5) Then You copy it to the Micro Card. Edge.dat must not be inside a folder on the card.
6) Then finish.
( I hope it help. Sorry if my tutorial isn't clear -_-. Cuz my English are pretty bad T_T)
11/3/2020 10:11:05 AM • Nintendo DS Lite • Answered on Nov 03, 2020
2answers
Freezing up
that happens to mine sometimes i smash it against the wall and it works its so cool
6/12/2019 2:19:12 AM • Nintendo DS Lite • Answered on Jun 12, 2019
4answers
Looking for master password for my secret diary ds
The Master Password to the game is oxygen. After you type that in you need to pick a new password!!!!!
3/31/2018 7:20:12 AM • Nintendo DS Lite • Answered on Mar 31, 2018
2answers
Error code 52100
Hi there! There are a couple options you could try to solve this problem!
To solve this error :
I would first check Nintendo's special notes router infomation page located here.
  • If you can't locate your router on Nintendo's special notes router information page, log into your router and change the basic rate to 1-2 and the transmission rate to 2. Try to connect again.
  • You can try to manually assign an IP address to the Nintendo DS as another device may be sharing the same IP address of the Nintendo DS.
  • To manually assign an IP address to the Nintendo DS, on a PC click Start > Run > type CMD and press Enter > type IPCONFIG/ALL and press Enter. On Windows Vista, click Start > type CMD in the Start Search box > click on CMD icon > type IPCONFIG/ALL and press Enter. The IP address for the Nintendo DS must be 10 digits higher than your PC, for example 192.168.1.200 becomes 192.168.1.210. Also make sure that the correct DNS is the entered under the DS manual settings.
Hopefully one of these options is your answer and you can easily fix your problem! Good luck! If you need any further assistance I would suggest calling Nintendo at 1-800-255-3700.
12/8/2017 11:20:04 AM • Nintendo DS Lite • Answered on Dec 08, 2017
3answers
How do i get downloaded games onto R4 card?
you dont say if you have the r4 softwear loaded on the sd card if not try the r4 website and download the correct softwear for your card,you should then be able to open the games you have downloaded,hope this helps
1/31/2017 9:53:36 AM • Nintendo DS Lite • Answered on Jan 31, 2017
How do i unlock parental control, if i forgot my
Go into the settings menu, Parental controls, reset parental controls. Click through the confirmation screens, and then it will give you a confirmation code and ask you to call Nintendo.
Instead of calling Nintendo, go to this form and enter the code. Even though it was originally written for the Wii, marcan's reset code generator will give you a valid code that you can enter into your DSi to remove the parental control.
3/28/2016 7:13:02 PM • Nintendo DS Lite • Answered on Mar 28, 2016
2answers
What is the difference in the ds lite and the super mario ds lite
It's just themed with Super Mario (coloured red with an 'M' logo) and includes a game. Specs wise, there is nothing different between the two.
1/8/2016 9:04:50 AM • Nintendo DS Lite • Answered on Jan 08, 2016
Keeps saying theres no disc card inserted when there is
When it says there is no card, the logic board can't read a card. So perhaps you used a defective card, or contacts are dirty or bent, or when it says so with more than one card, the device can have a defect, like a connection lost or as I said defective logic board.
4/25/2015 10:09:49 AM • Nintendo DS Lite • Answered on Apr 25, 2015
The top screen for nds is upside down
Go to invert screen that should help you out
4/9/2015 3:22:15 AM • Nintendo DS Lite • Answered on Apr 09, 2015
2answers
How to play music and movie on my nds lite.
In order to get movies for your Nintendo DS, you must first purchase a kit which includes: USB cord with a microSD card slot, a 512 MB memory card, and an adaptor that fits into the DS cartridge slot. This hardware package is available from DSvision for only about $37, and it will be available in 2008.
Once you have the hardware package, you can begin downloading movies at the DSvision website from your computer, and then transferring those movies to your DS with the hardware. One downfall is that you can't download movies using the DS Lite's Wi-Fi capabilities, although this may be something to look for in the future from Nintendo and DSvision.
Upon launch, there will only be about 300 movie titles available for download, but they hope to increase that number to 10,000 within two years. You will also be able to download TV shows and e-books as well.
4/2/2015 5:24:52 AM • Nintendo DS Lite • Answered on Apr 02, 2015
Why does light go on then immediately off again and my Nintendo D S won't charge Why does the light go on then straight off again and my Nintendo lite wont Charge
Is the light blinking while you wiggle the plug? If so there are one of two problems one is that your cord is broke. Or two the jack on your DS is broken. Try replacing the cord first as it is cheaper.
2/17/2015 4:58:07 AM • Nintendo DS Lite • Answered on Feb 17, 2015
The cartage is bigger than a sd card
Get some isopropyl alcohol and with a cotton swab clean the gold fingers on the cartridge. As long as they fit in the slot this should solve your problem. Best of luck to you.
1/8/2015 6:50:55 AM • Nintendo DS Lite • Answered on Jan 08, 2015
tip
DS Lite Slot -1, games cartridge not reading games repair / resolution.
Has your slot -1 games cartridge reader stopped working? Is it being temperamental with your cartridges? Here are a few tips to get your DS lite back to full working order.
1) First try giving the games cartridges metal contacts a clean, ideally with a cotton bud and white spirit (if you don't have white spirit try avoiding anything soapy, if you can try to stick to an alcohol based solvant such as nail polish remover).
2) If that doesn't work you can try cleaning the cartridge socket (slot1), you can buy proper cleaning cartridges for the DS lite, or, if your feeling brave you can get a jaye cloth, dampen it with an alcohol based solution (same as what is used to clean the cartridge) make sure it is well wrung out so that the cloth is only slightly damp and thinly wrap it around a rigid ruler, which can then be gently placed into the slot to give it a bit of a clean.
3) If both of those fail you may find that some of the pins within slot1 are bent/snapped and so this will need to be fixed, If under warranty i'd suggest taking them in to get looked at. If they are not and you feel brave you can set about fixing it yourself, take the DS lite apart and have a look at the pins on the slot1 socket, if they are damaged you can buy a replacement socket on ebay, but be warned it is a tricky job to solder a new one on.
To solder the replacement slot -1 on firstly you will need to remove the old one, take care not to damage the pcb tracks when doing this as it will cause the replacemet process to be far more difficult and a purchase of a track repair fluid may be needed. Your best option is to de-solder it buy removing the exisiting solder to free it from the motherboard. Once you have done this you need to put the new one on, take great care not to fuse any of the pin connections together with the solder as this will cause the DS great problems and break it. Re assemble the DS lite and give it a try.
If you need help with taking the DS lite apart please refer to my other tips and tricks posted on here.
Just so you know I take no responsability for any damage that may occur whilst following these tips.
Regards,
SOD69
on Jan 05, 2015 • Nintendo DS Lite
I have a regular ds player on the first ones and it want read some of the card .
If it is reading some card, but not others, the cards themselves may be damaged. It is also possible that the system is failing. You may want to consult with a local game shop and see what they have to say. It is hard to diagnose any system without looking at it. Good luck.
12/28/2014 2:45:56 AM • Nintendo DS Lite • Answered on Dec 28, 2014
Marvel lego cheat codes
Cheat mode :Pause the game, select the "Extras" option, and choose the "Enter Code" selection. Then, enter one of the following codes to activate the corresponding cheat function: Result Code Extras 2x Stud Multiplier UZFBG4 Minikit Detector 7VKCT2 Vehicles Avenging Cycle 5T3CQU Pumpkin Chopper 35E41W SHIELD Staff Car D5B7O3 Spider Bike SH9MZQ Characters Beetle Black Cat P9OWL0 Captain America (Classic) 7HWU4L Carnage AA0Z50 Howard The Duck J58RSS Hydra Soldier B7AA3K Iron Man (Mark 17 - "Heart Breaker") 2NGSRZ Iron Man (Mark 38 - "Hulkbuster") CK7SDS Iron Patriot MODOK SZ8Q06 Spider-Man (Future Foundation) WFOZXQ Thor (Classic) H8CSE6 War Machine TQ4C57 Wolverine (with hood "cowl") OAW2LB
9/26/2014 11:58:02 PM • Nintendo DS Lite • Answered on Sep 26, 2014
0answers
Nintendo DS Lite Logo
876 questions posted
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
DS Nintendo
  • DS Nintendo
Most Popular Question
looking master password secret diary ds
  • Video Game Consoles & Games
