20 Most Recent Nintendo DS Lite Red Console Questions & Answers
you have to pop the bubbles to prevent them from damaging the sample
Nintendo DS Lite... | Answered on Apr 20, 2015
Thanks for contacting fixya, our experts would be with you in a moment.
First, refer that device may have been acquired with several component parts many including written material. Normally, nintendo video games are already programmed to have an instant template where as additional cartrides containing shows can be come dispplayed on installion. Familiarise with device user guide on how to attain desirebly functionality of brand model.
Nintendo DS Lite... | Answered on May 15, 2013
your router is probably using a wifi pin number and the ds doesnt like it. try changing the wifi type on your router to wpa2
Nintendo DS Lite... | Answered on May 14, 2013
thank you for contactin fixya, experts would be with you in a moment.
You must have internet connection to upload pictures from your DSI to facebook. Make sure your DSI has the latest firmware update (go to the system settings menu and select system update). Then when you go to your album and select a picture, a Facebook icon should appear. Selecting this will open a page that lets you log in to Facebook and upload your photo.
Thanks for using FixYa!
Nintendo DS Lite... | Answered on Oct 25, 2011
the ds have an issue with the wire contacts in the game slot becoming bent or even breaking off- if less than a year old- you can go to NINTENDO web site for warranty repair- or try an online shop like VIDEOGAME911.com. good luck
Nintendo DS Lite... | Answered on Jun 20, 2011
Check for the battery indicator, if it is too low all the time, even after a complete charge, your battery might need to be replaced.
Nintendo DS Lite... | Answered on Jun 02, 2011
try pusing all the buttens at the same time and if tht dont work take it to a game store and get a used one
Nintendo DS Lite... | Answered on Mar 16, 2010
You might be able to fix this your self.You will need to solder some of the connections.First thing you need is a tri wing screwdriver you can get one on eBay for two dollars.their are seven screws holding the back on 4 tri wing and three cross.Be very care full not to break off the on off switch so when you go to open it start with the side that doesn't have the switch.Then once you get the back off you will have two more cross screws on the mother board so you can flip over the mother board and see the ds game card slot and if it is damaged or if one of the connection is broke but you cant see in side the slot.Nintendo will fix it for you but might be 60 or 70 dollars their are also people on eBay that will fix for a little less
Nintendo DS Lite... | Answered on Feb 28, 2010
Have a look down the game slot for any bent or broken pins if not the slot 1 game socket is not holding the game cartridge tight enough to the pins to make a good connection. there is a quick fix for this that has worked for me, only if you are confident enough to open up the ds, by pressing down hard enough to make a slight dent in metal peice on the logic board, press down the bottom corners and the middle with a small screw driver and that should cure the problem. good luck <tell me how it goes>
Nintendo DS Lite... | Answered on Jan 16, 2010
This sounds like the battery, if the unit is new, contact Nintendo or return it to the store. If not, you should be able to get a new battery for it.
Nintendo DS Lite... | Answered on Jan 02, 2010
Well basically you cant charge it without a power input source so you gotta buy a new one or buy a power replacment kit on amazon or ebay
Nintendo DS Lite... | Answered on Aug 23, 2009
Something popped...
I would bet money its either a cable from one of the lcds, a Fuse, or the Wireless Wifi Board. You might want to go ahead and send it in for repair. I don't advise anyone to open up a DS for the first time if you haven't been trained or don't care about even more possible damage. Its SO EASY to damage these things.
Nintendo DS Lite... | Answered on May 30, 2009
got it replaced
Nintendo DS Lite... | Answered on Mar 05, 2009
ok, you have a DS Lite with a bad housing. Normally these housings are perfect quality but I think this one slipped the end inspection.
It do not damage the working of your DS Lite but it is a visual issue. So if you are unhappy with it and the DS Lite is new, you can go to your reseller and let him see your issue.
If he will not help you, please contact Nintendo with this problem.
John
Nintendo DS Lite... | Answered on Nov 27, 2008
http://www.zeldadungeon.net/Zelda01-the-legend-of-zelda-walkthrough.php
Nintendo DS... | Answered on Jan 12, 2016
If the board (PCB) is not damaged you can re-solder the wires back. If the PCB is damaged you should be able to get new ones by looking up the make and model of the device and look for the specific part.
Nintendo DS... | Answered on Oct 12, 2015
Nintendo DS Lite Red Console Logo
Popular Tags
24 questions posted
Popular Products
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
DS Nintendo
  • DS Nintendo
Most Popular Question
ds millionheir get past dna sequencing
  • Video Game Consoles & Games
