20 Most Recent Xerox Phaser 6110 Laser Printer Questions & Answers
The image unit can be reset.
This is done by use of a small program that Xerox certified engineers use. The process is really simple and only takes about 30 secs, if you have access to the program ( I do... :) ) It can also be used to reset transfer belt life etc ....
Xerox Phaser ... | Answered on Apr 25, 2019
sad but when they made them to only accept factory cartridges they messed a lot of us up andyou can't even refill them
Xerox Phaser ... | Answered on Sep 11, 2016
Hello.
Unfortunately, Xerox doesn't yet offer Windows 7 support for your device. However, they announced a release of the Windows 7 driver until June 2010.
Still, you can try installing the Windows Server 2008 driver:
http://download.support.xerox.com/pub/drivers/6110MFP/drivers/win7/cs/Phaser_6110MFP_W7.zip
Source:
http://download.support.xerox.com/pub/drivers/Compatibility_Matrix/other/win7/en/Windows7_Matrix.pdf
Now ... are you sure your device is not 6110MFP? Because Xerox Phaser 6110MFP does have Windows 7 support and you can download the driver here:
Xerox Phaser ... | Answered on Apr 25, 2016
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Xerox Phaser ... | Answered on Nov 25, 2015
NOTE: Print a Configuration Page before resetting NVRAM. Press and hold the [Up] arrow button on the Control Panel, and then press the [OK] button. This will automatically display the Service Tools menu on the Display Screen.
  1. Press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
To reset the printers NVRAM using the Control Panel:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
Xerox Phaser ... | Answered on Oct 22, 2015
No reset for imaging unit, only when you change it(autoreset).
You can reset Fuser and Transfer Roller this way:
To reset the fuser and transfer roller life usage from the printers control panel:
a. From the main menu select, Menu-Setup --> Maintenance --> Check other.
b. Select the appropriate part name from the list by using the Up Scroll and Down Scroll buttons
c. Select Reset.
Anonymous I suspect something serious has caused a problem.
I expect you must have sorted the problem by now.
Good Luck.
Xerox Phaser ... | Answered on Jun 02, 2015
All models of machines have sensors to detect an overheat situation, feel free that the machine will shut down if it reaches too hot of a condition.
Xerox Phaser ... | Answered on Sep 16, 2014
Are you low on toner?
Else try reinstall the printer.
Phaser 6110 Support Drivers
Xerox Phaser ... | Answered on Aug 21, 2014
If you tried to print on a transparency sheet for ink jet printers, in your laser printer, you could have damaged the heating rolls. The plastic could be molten on the roll and you won't be able to remove it without damaging the roll. As long as there is just a spec of plastic on the roll you will have paper jams. There should be transparency sheets for laser printers to, but always make sure you have those before using in a laser printer.
Xerox Phaser ... | Answered on Jun 22, 2014
Try to disassemble the printer. On the left side try to find magnetic clutch with small tension spring. This must be the problem. You can disconnect the spring and try to cut a few mm of springs length, so she will become stronger. In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Xerox Printer Support
Xerox Phaser ... | Answered on Feb 26, 2014
Xerox Phaser  6110 Laser Printer Logo
146 questions posted
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Phaser Xerox
  • Phaser Xerox
Most Popular Question
black prints vague
  • Office Equipment & Supplies
