The Fn key is a key found usually on the keyboards of portable computers (laptops, netbooks etc) and sometimes on desktop type keyboards.
It is a key usually marked with a blue coloured "Fn" and is located somewhere on the bottom left row of keys.
The Fn key is used in combination with other keys that have (usually) blue letters or icons on them to activate the special functions (Fn) on these keys.
For example, on the laptop I'm writing this on; If I press F5 the computer would perform the action my software has normally assigned to F5. If however I press the Fn button and F5, the computers internal function for decreasing screen brightness is invoked.
Different computer makes have different assignment to their keyboard Fn so you can't generally say press Fn+F5 to decrease screen brightness, it might be assigned to something else, volume or sleep-mode or even nothing. The "blue" text or icon will give an indication of what it will do.
Hope this helps explain the Fn key ;)
F1 - Security System
Press and hold the "Fn" key on the lower left-hand corner of your Toshiba keyboard.
Press the "F1" key to activate the security system.
Your laptop's screen will go blank so others can't see what you are working on or accessing.
No Fix, No Fee. Same Day or Free. We Come To You - 1300 723 628
www.thepcdoctor.com.au/melbourne
Press any key or touch the touchpad to exit the security mode.
F2 - Power Save Mode
Press and hold the "Fn" key.
5
Press the "F2" key to activate the Power Save mode and make changes to how your laptop handles operating on battery or AC power.
6
Press "Fn" and the "F2" key again to exit the power save mode.
F3 - Standby Mode
7
8
Press the "F3" key to place your laptop in Standby mode.
The Standby dialog box will appear.
9
Verify you want to enter Standby mode. Press the power button on your Toshiba laptop to exit Standby mode.
F4 - Hibernation Mode
10
11
Press the "F4" key to activate the Hibernation mode and save whatever documents and files that are open to your hard drive.
12
Verify you want to enter Hibernation mode. Press the power button on your Toshiba laptop to exit Hibernation mode.
F5 - Active Display Device/F6 and F7 - Toshiba LCD Screen Brightness
13
14
Press the "F5" key to change your laptop's active display device from the laptop screen to an external monitor.
15
Click on the display configuration you want: displaying on both the laptop and external monitor; only on the laptop; only on the external monitor; or a specific screen resolution.
16
Press and hold "Fn" and "F5" to accept the new display settings. Press and hold "Fn" and "F5" again to return to your laptop's display only.
17
18
Press the "F6" key to decrease your laptop's screen brightness. Press the "F7" key to increase the brightness.
F8 - Wireless Connection/Bluetooth
19
20
Press the "F8" key to select the wireless Internet or Bluetooth connection you want to use.
21
Press and hold "Fn" and "F8" to make your selection. Release the keys to confirm your selection.
F9 - Touchpad Control
22
23
Press the "F9" key to enable your laptop's touchpad.
24
Press and hold "Fn" and "F9" again to disable the touchpad.
F10 and F11 - Numeric Keypad/F12 - Scroll Lock
25
26
Press the "F10" key to enable your Toshiba laptop's numeric keypad.
27
Press and hold "Fn" and "F11" to enable the cursor control keys on the numeric keypad.
28
Press and hold the "Fn" and "F10" or "F11" key to disable the numeric keypad or cursor control keys.
29
30
Press the "F12" key to lock your cursor on a specific line of text. Press and hold "Fn" and "F12" to turn scroll lock off.
hope this helps
