Windows Advanced Options Menu
Please select an option:
Safe ModeSafe Mode with NetworkingSafe Mode with Command Prompt
Enable Boot LoggingEnable VGA modeLast Known Good Configuration (your most recent settings that worked)Directory Services Restore Mode (Windows domain controllers only)Debugging Mode
Start Windows NormallyRebootReturn to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choiceyou could select the safe mode option and see if you can get the extended desktop again but first you will have to find out why it crashedif you select last known good configuration that worked it might give you an ideahope it helps
The message means you compressed your C drive. Windows can't even start that waywhich operating system ? if you dont have an installation cd http://www.ubuntu.com/download/ubuntu/download
which can repair what windows has ruined and is unable to fix fix the problem
either burn it to a disk as an iso and install it
its an open source operating system hope this helps
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cablesAnothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot
from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs
data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
hope this helps
62 questions posted
541 Questions
461 Questions
402 Questions
399 Questions
