20 Most Recent Dell Inspiron 6400 Notebook Questions & Answers
2answers
How can I reset MY windows password
Depends on what version of windows you have!
7/22/2022 9:29:41 AM • Dell Inspiron... • Answered on Jul 22, 2022
3answers
Error code 0142
wajhia,This error code represents a failed hard drive. It will need to be replaced. You can order a hard drive from the Dell Spare Parts Department by calling 1-877-717-3355 in the US. You can also go to you local computer shop to purchase a hard drive.Thank You,Dell-Jesse LDell Social Media and Communities
7/22/2022 9:26:32 AM • Dell Inspiron... • Answered on Jul 22, 2022
3answers
How do i speed up my older pc laptop?
2005 relic PC day. XP the virus magnet slow doing what? , guess ALL. all do that , with HDD for sure , HDD slows with age, is a fact. all old PCs are slow compared to new PC so buy newer better PC reliable /safe only happens in hands of pro, why want that ? and ask here we can';t turn the screw driver and not wreck FFC cables.! if ram is too small buy more ram, none told what compression?, that is not good, never compress the hdd. wow ! no OS told we can not guess OS, windows what? causes of slow, all. (besides scrap it) no order.
  • HDD is bad failing smart tests. (and will die soon) 10 years old hdd are mostly all bad now, you are the LUCKY ONE.
  • HDD is full , clean out files, not needed, like downloaded endless videos for sure.
  • put in SSD boot drive, and reload the OS to it. or clone HDD.
  • more Ram ? 2GB is max on this Pig gaming.etc. OOPS fail.
  • remove not used APPS for sure in the startup folder,for sure.
  • in task manager, make sure ram is not full and CPU not overloaded to 100% if yes this must be cured.
  • I bet RAM is fiull, 2GB is tiny. easy to fill up , the CPU is slow a Duo processor, Intel Core Solo processor!
  • do not clone any bad HDD that fails smart tests.
  • this XP PC the last one on earth running and is infected as all are and infections make PC run slower or worse, there is always worse here,(topic)
  • it ran for 10 years, be happy, buy i3 and up based PC. win
7/20/2022 6:47:35 PM • Dell Inspiron... • Answered on Jul 20, 2022
10answers
Dell 6400 bios password lose
4/11/2021 12:09:08 PM • Dell Inspiron... • Answered on Apr 11, 2021
2answers
Dell inspiron 6400 laptop not playing video CD and DVD
just install cyberlink power dvd then it will stgart playing all kind of video cds and dvds from dvd rom
4/7/2020 12:40:33 AM • Dell Inspiron... • Answered on Apr 07, 2020
2answers
I have Laptop make of Dell model Inspiron 6400 I
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSPIRONI6400/E1505&os=WW1&osl=en&catid=&impid
use this link and click on the CD/DVD section and find the model of your drive. Download and install the driver
3/25/2020 8:51:59 AM • Dell Inspiron... • Answered on Mar 25, 2020
2answers
My dell inspiron 6400 laptop cd/dvd drive wont
check your device manager, you might need to re-install the driver
3/25/2020 8:50:16 AM • Dell Inspiron... • Answered on Mar 25, 2020
2answers
How can I watch a DVD on my TV from my Inspiron
if u have a TV out signal port on ur laptop, u will need a DIN adaptor to connect from laptop to ur TV
else u need a convertor box that will convert ur connect to ur VGA out port on ur laptop and will send the signal to TV via the box to the audio/video in slot in the TV...u will also need some special cables...thsi will come along with the convertor box....look in google or ebay
3/13/2020 8:41:51 AM • Dell Inspiron... • Answered on Mar 13, 2020
2answers
Laptop DVD player producing choppy sound
chasmodem, did u try with other software to play the DVD? Sound like a Cyberlink PowerDVD problem to me.
3/13/2020 8:38:43 AM • Dell Inspiron... • Answered on Mar 13, 2020
4answers
DVD player
this is dvd drive problem
clean your dvd lens and restart and check it
11/7/2019 6:44:54 AM • Dell Inspiron... • Answered on Nov 07, 2019
2answers
Dell Inspiron 1526 LCD inverter unable to turn on
Go on ebay and buy a new inverter for less than $10. Go on youtube to see how to replace the dell inspiron 1526 lcd inverter or the dell inspiron 1526 lcd screen. I put the lcd screen on because sometimes the problem might be your screen. If things don't work after installing the new inverter board, then buy a new lcd screen off ebay. The inverter board and screen are easy to install. Just go on youtube.com to find a video that walks you through it. The inverter sits at the bottom of the lcd screen. Some are screwed on, some are welded onto the screen, some are held by a small piece of tape. Even if you have to pry the old one off, just put the new on on held by a small piece of tape. 10results for Dell Inspiron 1526 inverter board
5/11/2018 12:21:50 PM • Dell Inspiron... • Answered on May 11, 2018
3answers
Driver problem!!!!
try searching drivers separately in the net ..
1/29/2018 9:04:50 AM • Dell Inspiron... • Answered on Jan 29, 2018
My wifi internet connection keeps
Check the signal strength, in many cases of there is only one or two bars of signal it will cut in and out and make it impossible to do many things .
11/18/2017 6:13:57 PM • Dell Inspiron... • Answered on Nov 18, 2017
Last night I spilled green
Using one of the video listed take the keyboard off and see if the error goes away: https://duckduckgo.com/?q=dell+6400+disassembly&atb=v61-3_a&ia=videos If it does, then replace the keyboard, if not then you are looking at some more troubleshooting with safemode, eventviewer, etc
4/21/2017 8:19:55 PM • Dell Inspiron... • Answered on Apr 21, 2017
2answers
I am using Dell Inspiron 6400 notebook. When ever
The hinge is faulty and can be replaced.
For details on how to fix or replace the hinge - click on this WEB site :-
http://www.insidemylaptop.com/replace-broken-hinges-dell-latitude-c640-c540-laptop/
For parts check out these WEB sites :-
www.laptopparts.com.au/
www.laptopking.com/
www.laptoprepairparts.com/
3/20/2017 7:13:42 AM • Dell Inspiron... • Answered on Mar 20, 2017
Windows was unable to format my flash disk
It seems that the card is bad. Try to format the card on a different machine to rule out your Windows formatter.
9/27/2016 2:17:40 AM • Dell Inspiron... • Answered on Sep 27, 2016
3answers
Why turbo c does not work in windows 7 64 bit
You're a programmer you should know this. Turbo C is a 16 bit application. 64 bit operating systems cannot run 16 bit applications. You need to get the 32 bit version of Turbo C or upgrade to a newer compiler.
http://www.fileguru.com/apps/turbo_c_for_windows_7_32_bit
1/11/2016 6:20:08 AM • Dell Inspiron... • Answered on Jan 11, 2016
Where do I get new charger for Insiron E1505
Try Amazon.com or Ebay.com
11/2/2015 11:59:30 AM • Dell Inspiron... • Answered on Nov 02, 2015
Change xp pro serial
8/18/2015 1:31:07 AM • Dell Inspiron... • Answered on Aug 18, 2015
1,539 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
dell 6400 bios password lose
  • Computers & Internet
