SOURCE: Lexmark 2300 series
put your pointer on the taskbar and right click, there is a toolbars option, see if lexmark is listed in the toolbars, check it and hopefully you get what you want
SOURCE: Cannot print with Lexmark x4875, Windows Vista OS.
You need to cancel all print jobs for a printer, you must have permission to manage documents on the printer.
1. Open printers by clicking the "Start" button , clicking "Control Panel," clicking "Hardware and Sound," and then clicking "Printers."
2. To open the print queue, double-click the printer you are using.
3. Click the "Printer" menu, and then click "Cancel All Documents." Depending on the printer, the item currently printing might finish, but the remaining items will be cancelled.
Next, you may have to change the communication format called the "Spool format."
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 4800 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
If this does not help the situation, please describe any differences it does make.
SOURCE: Printer Driver to download for Lexmark 1200 Series All-In-One
You will need to uninstall and reinstall the printer driver. Please follow the steps given below:
To uninstall:
1. Click on "Start" and "All Programs."
2. Go to the "Lexmark "X1200" Series."
3. Click on "Lexmark Uninstall."
4. Click on "Next."
5. Click on "Finish."
6. Click on "Restart Windows."
You may copy and paste the web address below to access the Lexmark X1270 printer driver:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:537:0:0&emeaframe=&fileID=8165&searchLang=en&searchLang=en
Please use the following steps to download the Lexmark X1270 driver to your desktop:
1. Select "Window XP" from the drop down list.
2. Click on "Download Now."
3. On the "File Download" screen, choose "Save."
4. The next screen will be titled "Save As." Choose to "Save in Desktop" and click "OK."
5. You should see files being transferred.
****Note**** If your browser uses a different file downloading format than specified above, you will need to resort to your browsers help files for downloading instructions. The object of steps 1 - 4 is to download the driver to your desktop. This way it is easily accessible.
6. Once the files have completed downloading, double click on the icon with your file name.
7. On the "Win Zip Self-Extractor" screen click "OK." To unzip the downloaded file choose "Unzip."
8. A screen will then display the number of files unzipped successfully, click "OK."
9. Please follow the on screen instructions to complete installation of your Lexmark printer.
your's tech expert
Jeeth
SOURCE: lxbkaiox.exe entry point not found
try uninstalling all of the software and drivers. disconnect from the web disable your firwall and virus protection and re-install your printer. all iin ones are notorius for incomplete installs due to virus protections that see some of there drivers as virus like activity while they are installing, this should help you out
SOURCE: trying to install software for lexmark x2670 all
Have you tried to install under "safe mode"?
What did you format? What error messages are you getting besides off-line?
