20 Most Recent HP Deskjet 3915 InkJet Printer Questions & Answers
clean the buffer before fiving print and then restart the system. If the problem occurs same then reinstall the printer driver and then try to print
HP Deskjet 3915... | Answered on Jun 18, 2019
go in control pannel> printer> right click on your printer there was option use printer online click on it
HP Deskjet 3915... | Answered on Nov 18, 2017
Not without the setup cd.
Just follow the link
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&product=1139325
just select driver download as well as setup.
Mark
HP Deskjet 3915... | Answered on Feb 07, 2013
I had the same problem and just talked with HP technician Neeta and she showed me how to fix it. It's a bit convoluted. In essence you have to clear the print spooler. Here is what she told me.
First you have to be clear that there really ISN'T a paper jam by printing a test message this back door way.
Neeta : The USB cable should be disconnected. Neeta: To print a self-test page, press and hold the Power button. Raise and lower the printer cover four times. Release the Power button, and the self-test page prints
If the sel-test page prints, this means you truly do not have a paper jam. Next, clear the print spooler
Neeta : The USB cable should be disconnected.Neeta : Now click on start->RUN.Neeta : Then type "services.msc".Neeta : Then it will open the services window.Neeta : Now please look for the option "print spooler. Neeta : Okay, now , please right click on the option "print spooler" and click on stop then click on start, 3 times.
HP Deskjet 3915... | Answered on Dec 10, 2011
You can download the HP printer drivers from their supportWEB site. Please click on this link and
select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
HP Deskjet 3915... | Answered on Sep 09, 2011
The refilled cartridge could be bad. It may have run to low on ink and the nozzles may have melted Make sure the contacts on the cartridge and printer are clean. Wipe them with alcohol or Windex and let the dry.
Thanks for using FixYa
HP Deskjet 3915... | Answered on Aug 06, 2011
"All lights blinking and printer not responding" is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
The Solution is to try an older/another cartridge (doesn't matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the cartridge with copper "dots".
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge's electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
HP Deskjet 3915... | Answered on Mar 15, 2011
Many times HP and other manufacturer's provide drivers by Series rather than specific model numbers.
http://h10025.www1.hp.com/ewfrf/wc/product?product=1139325&lc=en&cc=us&dlc=en&lang=en&cc=us
That link should take you to your printer and all of the information and drivers you need for it.
HP Deskjet 3915... | Answered on Feb 28, 2011
I think that you should reread the error message.
Your printer takes ink not toner.
Replace the ink cartridge.
HP Deskjet 3915... | Answered on Nov 29, 2010
You need to go to the following link and install the Windows 7 Updates, ok?
HP Deskjet 3915... | Answered on Oct 13, 2010
The first thing I would do is download the latest drivers from the hp website. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=219&lc=en&cc=us&dlc=en&sw_lang=&product=1139325#N669 Once installed the downloaded software may run a wizard which will allow you to setup the printer failing that go to system preferences choose print and fax and then clcik on the "+" sign and if the printer is plugged in it should show up under the printer names select your printer and then the under the Print using select the print driver. Hope this helps
HP Deskjet 3915... | Answered on Sep 24, 2010
You can get the drivers from here.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=1139325&
Note that you will have to choose your operating system to see the drivers.
Sai.
HP Deskjet 3915... | Answered on Aug 26, 2010
sat to long without use and the heads are clogged
HP Deskjet 3915... | Answered on Aug 24, 2010
In that case the sensor on the door is most likely faulty . Try to reset it by opening the door, close the printer, open it again, close the door and wait 1 minute then close the printer again; unplug it from the wall for 15 minutes and start it up. If the problem is still there you will have to dismantle the printer to access the sensor for testing.
HP Deskjet 3915... | Answered on Aug 17, 2010
HP Deskjet 3915 InkJet Printer Logo
75 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
printer connected
  • Office Equipment & Supplies
