Televison & Video Logo
Posted on Dec 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sirs and mesdames: I have a Symphonic TV/VCR COMBO model # TVCRI3E1. The remote control part # (UREMT32SR007) is missing. Where can I find a replacement? Thanks, Ilia Rivera
Level 3:
Top Expert:
  • Funai Master 76,851 Answers
  • Posted on Dec 24, 2010
Funai Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008792
Points
237762
Hello
Just buy one Philips Universal Remote control Model number [CL 034]. You can synchronise it with your Symphonic Combo by entering one amoung the following codes. Proceedings are also given.
Note: Switch OFF and Switch On your combo, before entering each code.
Three digit codes for Symphonic are:-
033/ 053/ 189
Four digit code for Symphonic TV/VCR combo is:-
0227
Four digit remote codes for Symphonic tv are:-
0053 0189 0227 0456 0024
Four digit codes for Funai are:-
0051 0189 0053 0227 0456 0042
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
You can also check according to the catelogue of that remote control also. The above given numbers are most common for all universal remote controls. OK.
Need instructions for codes for jumbo remote for symphonic tv with vcr
Hello
Setup code for Symphonic TV/VCR with Jumbo remote control is: [002].
There is no setup codes for TV/VCR combo with RCA RCU600M remote control. OK.
3helpful
2answers
I need the code to reprogram my Symphonic tv/dvd/vcr with a GE Universal Remote 24944
Symphonic tv codes are 0053 0189 0227 0456 0024
tv/dvd combos 0456
dvd/vcr combo 0456 {0458 & 0227}
{0899 & 0236}
hope this helps if not i can scan the code list for you
Can I buy a remote for Symphonic TV, model SC3819?
sure you can check out partstore.com they have original remote for your tv.good luck.
In need for remote code number(s)
Yes I have solved my problem. Thank you very much for the help. I came across a web site that gives you the TV codes so I can program my Direct remote.Thank you again.
Please help!!!
Try the remote's "search" feature. If that does not work, then the remote doesn't have a code for that unit.
Hope that fixed ya...
Geno
2helpful
3answers
Remote code
I NEED OTHER REMOTE CONTROL AT POLAROID TBX-2000AF 20 IN TV/VCR/DVD COMBO. THANK YOU
3answers
Symphonic - 19 televison, B 19WM
This set doesn't have that option...accordianman
Top Funai Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
