20 Most Recent
Universal Remote Control GE174Universal Remote Control Questions & Answers
Ge 24977 remote control code
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to
many popular brand remote controls are given.
Three digit, four digit, five digits and two-digit code list are
there. Check the site with
patience. Surely you'll get a solution
to your problem. Search the site by
'Timeslide' option. It will make search
easy. Or, type in the brand name to
your device into its search box, and press "Enter"
Check this site too.
I need codes for a ge universal remote model rc24914-e. my tv is an emerson
0382,0819,0284,0618. Check these codes. If you wish to get more details, check
this site.
Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device
I need the code to reprogram my Symphonic
Symphonic tv codes are 0053 0189 0227 0456 0024
tv/dvd combos 0456
dvd/vcr combo 0456 {0458 & 0227}
{0899 & 0236}
hope this helps if not i can scan the code list for you
Need code for GE universal remote for apex tv
0271,0277. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Code for Emerson cr202em9 tv
You should look up the code for your device in user's manual of your Universal Remote. If it's not there, you should follow the indicated search procedure. If can't find any, should buy another universal remote but before buying, check it it has the code.
