20 Most Recent
Symphonic SC319C 19 in. TV/VCR Combo Questions & Answers
The vcr tape is stuck
press rcord and then it shuode come out. it will switch it selfoff then prees ejeckt.
I also have a 19" Symphonic tv vcr combo which
The problem is with the vcr section, it is stuck in eject mode thinking there is a tape. This a mechanical problem that might be repairable. The tv and vcr share some of the same circuits, you can try resetting the tray in the out position as if it fully ejected the tape. Now if this does not work it means you have a gear timing problem or bad sensor.
A friend gave ne an old Symphonic TV with its
u can go 2 buy a universal remote with a handbook 2 tell u how 2 program it lol.b alot easier.that way if u have dvd & vcr...it can b programmed 2 operate it as well as the tv!universal remotes r the best sollution lol.lazier the better lol.
Symphonic tv vcr combo will not eject tape
You need a new VCR belt it located on right side of the vcr tray take your finger and start rotate the belt clockwise, it should release the tape. or the motor is going bad.
No sound on TV but VCR is OK
Hi there, This sounds like an input control error.
If you find the menu section, then choose Av inputs, you can adjust the settings, I.e. stereo Video or Av (if you are using scart leads then choose Av.
Hope this helps, Chris
Remote signal not received?
If u can get to the INSIDE front, clean the window of the receiver eye.(of cause the outside also!) If the wires going to the board can be unpluged, unplug, the push it back in. Possable that the receiver eye circuit is too heated up.Put a small (square boxed computer type fan) in the back of the tv to cool it down some.If u know how to "glue" a HEATSINK to the chip to get rid of the heat, may help.
note: it is possable that BOTH regulor and universal r/c are intermittance (sometimes works, sometimes don't work)
Tv vcr combo
The best way I can think of is to REMOVE the rubber band that loads the tape into the transport unit.Be KILLFULL (careful) the band is right next to the B+ (power supply) or the A\C 120volt
( and if u can find the replacement rubber bands, buy 2 kits)
Power problem
Problem in tape transport mechanism, most likely...accordianman
Tape stuck in vcr
Carriage has been set out of alignment due to improper extraction- need to repair or replace the carriage loader...accordianman
TV Problem
i have this problem too i dont know how to fix it either
DVD operation
scroll down on the channel button from channel 2. the different aux inputs should be there.there may also be a video/line in/source button on the front of the tv.if there isn't, you can buy a cheap universal remote for under $10 [even in some dollar stores for $1]
wg
