20 Most Recent
Symphonic WF-719 19 in. TV/VCR/DVD Combo Questions & Answers
The remote won't work with tv and the batteries have been changed
Most TV shops can test the remote to see if sending by pointing the remote at it and pressing buttons.Many digital cameras in a dark room will react with a tiny flash of light on the camera display when the remote is pointed at it and buttons pressed.The remote may also if not working be repaired by most shops--we get 5 dollars if we can fix one--usually easy money.
How can i access the
Purchase a replacement 'universal' remote - widely available from electrical / tv stores
Tv wont turn on
Hi tii, my name is John. Welcome to FixYa. Check that you have power to the unit. Unplug it for one (1) hour and see if it will reset. If you still have a problem with it and are not affraid of high- voltage, because it is deadly. Re-post and let me know, I will post the steps and tools needed to repair it. Thanks for choosing FixYa. Happy Holidays.......John
I can't find a code to set the remote for my
Hello, on some of these combinations you might have to try not only the TV codes on your universal remote list, but also the DVD or VCR codes also. One of these three will program your universal remote, but make a note: you may have a partial function on your remote ie: power, but no volume control or channel scan(up/dn) or no number operation(0-9). This happens on some of the universal remotes not all of them. thanks!
Symphonic Model# SC319A
did you try leaving a tape in the vcr?mine did that and when i left a tape in it worked fine. good luck.now i cant get a tape out...lol
Antenna/Cable Switch
You can get a 75 Ohm to 300 Ohm balun from a local Radio Shack Store and connect it to VHF antenna but you won't be able to receive off the air signals for very long because in about a month all TV signals will be being broadcast in Digital Format nationwide and all you will receive is SNOW. You'll need to also buy a Digital to Analog conversion unit as well to receive off the air programming. Sorry for the bad news but that's the advancement of technology and mandates from our government (FCC).
Hope this helps and Happy New Year,
Backyard_Jim
