20 Most Recent
Funai LC427SSX 42 in. LCD TV Questions & Answers
I have a 48 cm
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Funai dvd recorder e3 error
THat means it is unable to record successfully.
Try cleaning the lens with compressed air in a tin, (used for cleaning).
Do Not use a cleaning disc, as that can lead to permanent damage to the lens and focus coils.
How to reset my funai TV resolution mismatch
On your remote control, press MENU.
Highlight Settings with the down arrow button, then push OK.
Press OK after highlighting Television with the down arrow button.
Select TV resolution, then click OK.
Select HD 720p, HD 1080i, or HD 1080p using the arrow buttons.
Click OK.
FUNAI
What's the question?
