The first thing I would do is download the latest drivers from the hp website. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=219&lc=en&cc=us&dlc=en&sw_lang=&product=1139325#N669 Once installed the downloaded software may run a wizard which will allow you to setup the printer failing that go to system preferences choose print and fax and then clcik on the "+" sign and if the printer is plugged in it should show up under the printer names select your printer and then the under the Print using select the print driver. Hope this helps
