20 Most Recent HP LaserJet 1300 Printer Questions & Answers
NONERIGHTNOW, HP makes great laser printers, the commercial LaserJets typically last 8+ years without much more than an occasional maintenance kit to keep them going. The 1000 series printers are quite another story, they are designed for the low end printer market and just can?t take hard usage over time. The typical culprits with paper wrinkling are heat from the fuser or paper problems. -In the paper tab of the printer driver make sure the correct media is selected. This controls how hot the fuser gets which also causes paper curl/wrinkling. -Buy some fresh HP grade paper, improper humidity, coatings and storage can also cause problems. -Try a new HP cartridge. If you still have no success starts a print job and turn off the printer while the paper is feeding. What you want to do is try to freeze the wrinkling process so we can identify what area is causing it. Post this information. Also open the rear, straight through door; also let us know what happens. Let us know how it goes and please don?t forget to rate this posting.
HP LaserJet 1300... | Answered on Aug 28, 2019
If you need service for your hp printer. you may visit HP Customer service or dial toll free number- 1-800-585-2494. hope this will help you better.
HP LaserJet 1300... | Answered on Apr 30, 2019
Hi Good day pls do the following
1. Turn off your printer after a few seconds turn it on
2. Click "Start" - "Setting"
3. Click "Printer and Faxes you should see your installed printer
4. double click your printer now yous should be on the printer queue box.
5. Click Printer in the printer queue box, and then select connect.
the printer should be online now hope.
looking forward to assist you more.
REGARDS
JR
HP LaserJet 1300... | Answered on Jul 12, 2018
Give a call to HP Support (877-690-9305) you will get the solution for the orange light issue.
Support For Hp Printer Call Toll Free 877 690 9305
HP LaserJet 1300... | Answered on Apr 19, 2018
press the big button, and let me know what leds be lit and what will be shut down, contact me at walid_sayed@hotmail.com to tell you what is the error code mean
regard
HP LaserJet 1300... | Answered on Apr 03, 2018
You can click on the link below to download the drivers for your printer model.
HP Laserjet 1300 Driver Download Page
HP LaserJet 1300... | Answered on Dec 27, 2017
You need to clean or replace the imaging unit. Driver probably won't help.
HP LaserJet 1300... | Answered on Apr 02, 2017
to check the toner level just press the button and wait the second light(orange) to turn On and then release the button. The printer will print two pages one with configuration and one with the supply status of the toner cartridge
HP LaserJet 1300... | Answered on Aug 16, 2016
Write your answer...my hp laserjet 1300 is not worn when I oNn it
HP LaserJet 1300... | Answered on Apr 22, 2016
Pull out the tray, restart the printer, put the tray back and try, it should read try normally. Regards, Mike
HP LaserJet 1300... | Answered on Apr 07, 2016
Re-installing the print driver will not solve a flashing light. If the printer is functionally ok, it will come to ready simply by plugging into the wall. It sounds to me like a fatal error at this point.....could be a long list of things, but I would lean towards a formatter board. bottom line with this printer at this point in it's life is, if it doesn't work, it's not worth fixing. Replaceable for about $100.
HP LaserJet 1300... | Answered on Jan 17, 2016
Go to the HP support site and download the latest drivers and software for your printer compatible with your Operating System. After installing shut off the PC and reboot and plug the Laser Printer back in and try again.
HP LaserJet 1300... | Answered on Apr 10, 2015
Not picking up paper is usually caused by feed and pick up rollers worn out and has slick spots on then. Replace the rollers
HP LaserJet 1300... | Answered on Jan 31, 2015
Which light is flashing? These codes all tell you something but I needs some details. A blinking light usually does not mean a fatal error but provide some details and I will try to help you.
HP LaserJet 1300... | Answered on Nov 25, 2014
It uses cartriges HP 95/98 (product nr CB327FN)
HP LaserJet 1300... | Answered on Jul 14, 2014
HP LaserJet 1300 Printer Logo
435 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
please sir need service manual hp
  • Office Equipment & Supplies
