HP Deskjet 3915 InkJet Printer Logo
Posted on Aug 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The printer says that the door is ipne, and will not print but it is completly closed.
Azrael SRL
Level 3:
  • HP Master 11,800 Answers
  • Posted on Aug 17, 2010
Azrael SRL
HP Master
Level 3:
Answers
11800
Questions
0
Helped
2567114
Points
35672
In that case the sensor on the door is most likely faulty . Try to reset it by opening the door, close the printer, open it again, close the door and wait 1 minute then close the printer again; unplug it from the wall for 15 minutes and start it up. If the problem is still there you will have to dismantle the printer to access the sensor for testing.
Mp c5502. Why does it keep displaying 'door open' even though it's closed?
Sometimes Door open error shows in printer even if it is closed .
Follow This steps to Fix Open Door Error Message:-
*Close the cartridge access door completely.
*Check the cartridge door for obstruction.
*Reset the Printer
*Restart the Print Spool Device.
*Restart the computer.Restart the Printer.And If you are using Brother Printer And You Encounter With Brother Printer In Error State Windows 10 Issue then Read The Blog I Am Mentioning above.
Yellow light blinking
Top light blinking means: door open, media out, no print
cartridge, or media jam This printer is in an error state that
requires operator intervention. Check the following:
- The print cartridge door is completely closed.
- Media is loaded. See Loading media into the input trays on page 24 for instructions.
- The print cartridge is correctly installed in the printer. See Changing the print cartridge on page 51 for instructions.
- There is no media jam. See Clearing jams on page 68 for instructions.
Here is the manual.
Thanks!
10.1002 supply error
This error indicate the affected cartridge...
10.1002 = Magenta e-label is missing..
you need to reinstall the printer..
Are you sure that the print cartridges are genuine!!
->Open the front access door completely.
->Press the blue handle on the print cartridge drawer to release it, and then pull the drawer out completely.
->Grasp the center of one of the print cartridges, and then pull it straight up to remove it.
->Hold the print cartridge so that the imaging drum faces the bottom of the print cartridge drawer, and then insert the print cartridge into the correct slot.
->When you are sure that you have genuine print cartridges installed, close the print cartridge drawer completely.
->Close the front access door completely.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Describe your HP LaserJet 1012 Printer Problem light flashing
If your HP Laserjet 1012's attention light is flashing,
Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
2answers
It keeps on sayin my access door is open but my printer doesnt have a rear door
Access door is usually the one that opens to allow the insertion of new cartridges. Try opening and closing that one and restarting the device after completely unplugging from the mains and waiting 30 secs.
Please rate this answer!!
Cheers
Bob
1helpful
Won't print, orange triangle with exclamation point
This triangle light blinking indicates that a door is open. Open the front access door completely. Close the front access door completely. Open the rear door and close it.
If this didn't fix it refer to this guide for all errors you get with this printer from HP website.
My printer is showing an E sign, and flashing lights next to the ink symbols, but I have changed both cartridges
Issue : One or both Check Print Cartridge lights are blinking. On light Resume light Check Print Cartridge light Paper Type lights On Off Blinking Off Figure 7: Check Print Cartridge light is blinkingc01058982.gif Cause 1
The print cartridge access door is open.
Solution 1
Make sure that the print cartridge access door is completely closed.
Figure 8: Close the print cartridge access doorc00858057.jpg Cause 2
The print cartridges are missing or not seated correctly.
Solution 2
  1. Open the print cartridge access door. Allow the carriage to move to the center of the product.
  2. Make sure that both print cartridges are installed. If one is missing, obtain a compatible print cartridge and install it in the slot. To check the cartridge compatibility for your product, go to HP SureSupply . To identify your cartridge type in a language other than English, click the language link that appears near the globe icon in the top right corner of your browser.
  3. Run a finger along the top of the print cartridges. If any are sticking up, gently press the print cartridge down and forward into the slot until it clicks into place.
  4. Close the print cartridge access door. If a new print cartridge is installed, the product automatically aligns the print cartridges.
  5. Try the print job again.
Cause 3
The plastic tape was not removed from the print cartridge.
Solution 3
  2. Gently press down on each print cartridge to release it and then slide each print cartridge away from the product, out of its slot.
  3. Turn the print cartridge over so that the ink nozzles are facing up and make sure that the plastic tape has been completely removed from the print cartridge. Remove any plastic tape that remains. CAUTION: Do not touch the ink nozzles or the copper-colored electrical contacts on the print cartridge.
  4. Slide each print cartridge into its slot and then gently press the cartridge down and forward until it clicks into place.
  5. Close the print cartridge access door and try the print job again.
Cause 4
The print cartridge is not intended for use in this HP All-in-One.
Solution 4
  3. Make a note of the number on the print cartridge label.
  4. To check the cartridge compatibility for your product, go to HP SureSupply . To identify your cartridge type in a language other than English, click the language link that appears near the globe icon in the top right corner of your browser.
  5. Make sure that each print cartridge is compatible with the product. If both are compatible, reinstall the print cartridges, close the print cartridge access door, and continue with the next solution. If the print cartridges are not compatible with the product, replace them with genuine HP print cartridges that are compatible with the product.
Cause 5
The print cartridges might be defective.
Solution 5
Replace the print cartridges with genuine HP print cartridges that are compatible with the product.
NOTE: The printer might be packaged with only a tri-color print cartridge.
If all of these steps have been completed and the lights continue to blink, continue to the Service the
1helpful
Printer shows error code 3802 printer will not print
To resolve this error:
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Wait 30 seconds to allow the printer to reset.
  4. Connect the power adapter to the printer. Turn the printer on if necessary.
    • After the printer completes powering up, the message "Printer access door open" will appear.
  5. Close the printer access door.
If the error continues:
  2. Remove and install the printhead two times.
  3. Close the printer access door.
  4. Wait until the printer is ready to use.
If the error continues, contact Kodak.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
3helpful
2answers
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
52 error problem
You can try following .....
An easy fix is to close the toner door completely. If this door is not completely closed, the printer will not allow the laser shutter to operate, thus giving this error.
Other items that U can fix themselves are to re-attach the black connecting link to the Toner Door Hinge.
If the inner door has popped out, you can snap that back into place
k24674
Grand Canyon Tech
Grand Canyon Tech
