MAke sure your power cable of scanner and adapter working fine.
Some times improper voltage create this issue.
So change power adapter then check .
Also try in different power outlet.
Let me know if you need further assistance.
thanks for using FixYa.
Hi
Does your computer notice / detect the scanner? if it does not, then the power supply might not be working or it might not be plugged in, you might need a new powersupply or then the scanner itself might have a fault that prevents it from starting up, try unplugging it for a while and see if it helps, also make sure that the power adapter is the one ment for this scanner, a different adapter that doesn't give out exactly what the scanner requires might damage it.
A new basic scanner doesn't cost much, so replacing parts on this one might be more costly than buying a new one.
Scanning from Photoshop it send me directly to the troubleshooting message. I've detected that my scanner is not starting up, I mean, the light is not on and it does not even make the typical noise when is turned on (completely frozen!!) It is probably the 1st or 2nd time I've used it since new (8 months ago) but is refurbished from Epson website. Any advice or how to fixed? It was never beaten or anything. thanks
