20 Most Recent Canon CanoScan LiDE 500F Flatbed Scanner Questions & Answers
How can I fix error code 2,173,0 ??
https://microsoftofficesupport.org/ you can read their blogs.
4/16/2018 9:13:26 PM • Canon CanoScan... • Answered on Apr 16, 2018
There is not enough free
Hi ,
It seems obvious that you should free some space on your hdd by deleting the excessive amount of useless files .
solution 1 :Clic on " computer" or " my computer " , right clic on C ( primary HDD ) and go to Properties \ Disc clean up and follow instructions .
solution 2° :If your Hdd is partitionned C and D , you can increase space on C wit Partition Wizard from
http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html
Hope this can help .
Thanks for visiting FixYa .
Regards .
8/5/2015 9:01:52 AM • Canon CanoScan... • Answered on Aug 05, 2015
6answers
Canon LIDE 500F scanner does not scan - returns error message about releasing lock switch, detaching interface cable and reconnecting
Check the lock switch and make sure it is unlocked. I think the lock switch is on the bottom...or it may be under the lid near one of the hinges. Flip it back and forth and leave it in the unlocked position.
If this doesn't work, then it will most likely need service. Contact Canon Tech Support.
3/17/2015 8:16:04 PM • Canon CanoScan... • Answered on Mar 17, 2015
Why can I not run my Lide 500F scanner with a Windows 7 PC?
I have a cannon flat scanner 2000 & I came across this once before, I uninstalled all the cannon drivers then re-started the PC & next instead of using the Cannon drivers, I used Microsoft's Drivers & it's worked fine ever since. I hope this works for yourself as well. Best Wishes. Malcolm.
7/17/2014 4:11:12 PM • Canon CanoScan... • Answered on Jul 17, 2014
Canoscan LiDE 500f Driver for linux ubuntu
Stelios: there is no "linux" choice on the link you provide. thumbs down, looks like you haven't even tried dwonloading it, without mention to getting the device to work with the "driver" you suggest.
1/27/2014 5:24:58 PM • Canon CanoScan... • Answered on Jan 27, 2014
How to release lock switch in CanoScan Lide 50
at bottom
9/16/2013 12:09:27 PM • Canon CanoScan... • Answered on Sep 16, 2013
Install canoscan LIDE 500F
Hello you can download the driver here:http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide_500f?selectedName=DriversAndSoftwareIts free and remember to select your current operating system 32 or 64 bit.Good luck
10/12/2012 3:38:28 PM • Canon CanoScan... • Answered on Oct 12, 2012
5answers
Scanner not working
hrm, i found out how to solve the issue. remove the film and do a calibration for the frame, now the scanner starts to calibrate, after a 30sec the program told me to put the film in and scan.
tadaaaaa..
8/11/2012 2:13:04 AM • Canon CanoScan... • Answered on Aug 11, 2012
My canoscan lide 500f can
Sir,
Your scanner problem cleared not easy. may be changing processing unit board (PCB)
3/23/2011 12:45:21 PM • Canon CanoScan... • Answered on Mar 23, 2011
Driver for lide 500f for ubuntu/linux?
From this link select linux as your op. system and the desired language and download the drivers you asked for.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
3/8/2011 4:56:03 AM • Canon CanoScan... • Answered on Mar 08, 2011
I have been using it
Hi
Scanning require disk space in you computer. Try to remove some clean up or remove some document files in your hard drive to free some space. Check also your C and D drive jf how much disk space it available.
1/13/2011 4:04:02 PM • Canon CanoScan... • Answered on Jan 13, 2011
Can't scan to jpg
I don't know this device but you could try with a third party twain program such as FreeKapture from
http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
1/1/2011 6:45:18 PM • Canon CanoScan... • Answered on Jan 01, 2011
Canon CanoScan LiDE 500F Flatbed Scanner Logo
70 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
CanoScan Canon
  • CanoScan Canon
Most Popular Question
canoscan lide 500f driver linux ubuntu
  • Office Equipment & Supplies
