Epson WorkForce WF-4630 Wireless Color All-in-One Inkjet Printer Logo
Julie Hegarty Posted on Jun 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PRINTING ERROR MESSAGE?
ERROR CODE OXF4...WHAT IS THIS AND HOW CAN I FIX IT?
Electro Med Services
Level 3:
  • Epson Master 6,694 Answers
  • Posted on Jun 20, 2016
Epson Master
Level 3:
Answers
6694
Questions
Helped
1872700
Points
21433
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
2answers
How TO Fix Hp Printer Error 0x610000f6?
Well known issue and easy fix
Error Code '0x610000f6' Message Displays for HP Photosmart ...
support.hp.com > ca-en > document
Error Code '0x610000f6' Message Displays for HP Photosmart Plus All-in-One Printers (B209a, B209b, and B209c) · Issue · Solutions · Solution one: Turn the printer ...
Different Ways for How to Fix HP Printer Error 0X610000F6
www.printerfixes.com > Brand Related Issues > HP
HP Printer Error 0X610000F6 also known as Carriage Jam Error occurs very often in the Photosmart HP Printers. When a jam occurs in the printer due to paper scraps or due to any other reason, the printer stops working and it doesn't print any document.
VIDEOS as well
https://www.google.com/search?q=Hp+Printer+Error+0x610000f6&rlz=1C1QJDB_enCA643CA644&oq=Hp+Printer+Error+0x610000f6
Error code oxF4 on my WF 2660
Try the user manual for answers because I can't find that error code. Here is the link to the user manual. https://files.support.epson.com/docid/cpd4/cpd40871.pdf
MY EPSON WF-4630 PRINTER IS STUCK ON oxf4 AND WE CAN'T CLEAR IT. WHAT DO WE DO??
If you are lucky, the 0xF4 error indicates a foreign object (a scrap of paper) in the gears. That would translate to PF driver mechanism overload. Another cause would be a contaminated encoder scale. Fixing either of these will require you to disassemble the printer. Here are some tips for taking apart the printer: https://www.ifixit.com/Guide/Repairing+EPSON+B-510DN+Error+0xF2+or+0xF3/11767 .
However, the 0xF4 error could mean that the encoder board or the motor have failed. These errors can only be fixed by a service technician. If your printer is under warranty, you should call for service. Otherwise decide if you want to risk taking it apart and finding that you can't fix this error. It may be cheaper to replace the unit.
I hope this helps.
Ntoskrnl.exe creates blue screen
Well we cant see that image because it is not posted. The link shows it is on your hard drive. Also you need to tell us what the game is and the rest of the oxf4 code and what version of windows you are using.
7helpful
3answers
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
3helpful
Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
2answers
Error message unable to print
Send it back. The printhead voltage is innnnn disorder. Netxt will be Error 41 (Every Error starting with 4 means probs with printhead and in 99,9% the head has to be changed and cant be fixed!)
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
