20 Most Recent
Acer Aspire 5735 Notebook Questions & Answers
My Acer Aspire 5735z has no sound on dvds in Real
use the driver cd which came along with your laptop and reinstall the audio driver from it. After that reinstall the real player as well if needed.
After that everything should work fine.
I hope this is helpful to you.
Thanks
How can i reset the whole lap top (acer aspire
If you need to reset it to factory values, turn it off, turn it back on but keep pressed the F8 key until you see the BIOS configuration.
Select default values, save changes and exit. It will restart with the factory values.
I am trying to format my acer aspire 5735z laptop.
To change the bootable device you need to go to bios setting. Depending on your computer make and model the way to go to bios could be different though generally you can go to bios by continuously tapping on F1 or F2 or F9 or F10 or F11 etc The moment you press the power button and you see flashing brand scree like dell, hp etc. start tapping on F1 or F2 or F9 or F10 or F11 only one key at a time.
The best option is to install any version of windows is to use Wintobootic search and download it on a computer. Use any storage device like external hard disk or pen drive. make sure the storage device is completely blank when you make it bootable. insert your windows CD and Open wintobootic, select source and make bootable storage device.
for more info Visit :
http://leadingpcfix.com/
Ntoskrnl.exe creates blue screen
Well we cant see that image because it is not posted. The link shows it is on your hard drive. Also you need to tell us what the game is and the rest of the oxf4 code and what version of windows you are using.
Not installing skype
The only suggestion I can offer is install an earlier version of Skype to see if that will make the difference, also! go online to Acer and contact customer support and the technical department to see if they can shed some light on the problem.
Laptop stops loading after password screen...
Go back into system restore and restore the system to a previous point. This is most commonly a virus that locks down your icons. If you can get it to restore to a prior point then make sure you run your antivirus scanner and look for viruses and get rid of them. Hope this helps. Thanks!!
Computer keep restarting and dvd/cd drive doesnt
What did you do last? It sounds like there is a driver conflict. I would try to go to system restore. When you turn it on, pres continuously the F4 key to open recovery manager. Go to system restore from there. Choose a recent restore point.
Hello my daughter has an aspire 5735 and the
Sometimes you have to tell it what to boot from. It may say something at the bottom like f12 for boot options when turning it on. It could be a different function key. There is no standard for this.
Why says Linksys: wifi card disable
You Wi-Fi card can be disable for many reasons. First make sure that it is on. If it is the go into device manager under network adapters and make sure that it has NO yellow triangle. If it does have a yellow triangle or a red exclamation make right click on it and click update drivers.
I need to do a factory reset on the acer aspire
Try these 3 methods..
1. As the machine boots, hit F2 to enter the BIOS. Enable 'Disk-to-Disk Recovery', save settings, then exit.
As the machine re-boots, hit Alt & F10 and follow the prompts.
This will also restore the machine to its factory defaults.
2. Also, try pressing the 'E-Power' button at the extreme top-left of the keyboard (the one with the stylised 'e' on it, if you have Acer E-Recovery installed, this will also do a restore.
3.If that dont work try this..restart laptop and hit f F8 before windows starts logging on. You will get a list of menu choices, At the very bottom of the DOS like window, there should be an option
Restoring factory settings
if you are in win 8 then go to pc settings go to general and select reset
if in vista or win seven then control panel and restore factory settings
Tray App msi repair
When you get the error for missing trayapp.Download full feature software and drivers from hp.com. After extracting the downloaded file. Go to your my document's folder. Click tools, go to folder options and make sure to enable "show hidden folders". On the missing trayapp error message, click browse, go to my computer, go to disk drive C:, go to user and document settings, open the folder that has your login name, look for application data > local > temp > open a folder named 7z345 or any folder that has 7z for a file name.. open setup > open trayapp > then click trayapp.msi and click open.. a long process but that should solve your missing trayapp problem.. if you need help, i suggest you call hp
How do I connect my Laptop Acer 5735 to my TV Sony
If Your TV and Laptop have HDMI Port then you just need a HDMI Cable.
But if you dont have HDMI port. then you need two cables one from video and one for audio.
For Video you either VGA Cable(if you have VGA Port in your TV) or VGA to RCA Cable (Yellow Pin will be for video)
For audio You Need 3.5mm pin to RCA (white and Red for audio).
This pic is of VGA to RCA Cable
