20 Most Recent
Lexmark E450dn Laser Printer Questions & Answers
Error 950.10 NVRAM mismatch. how do I fix or
The way that I have found to fix this problem is to replace the logic board but when you do that, this is where the NVRAM mismatch comes in. Once you change the logic you also have to change the display op panel. That is what is giving you this error. You must change logic and op panel at same time and it will not give that error.
It keeps reading 935.10 service
Turn off printer and turn back on after 30 seconds to give it a chance to reset. Make sure the printer is plugged in straight to the power outlet in the wall. Bypass any surge devices or power strips, even if the printer previously worked correctly with these, as they can cause low amperage problem which can trigger a false printhead error. You can also try to plug the printer to another known working power outlet just to eliminate the power source as a possible cause of the issue. If error continues, printer may require service. Contact Lexmark technical support or an authorized service provider for further assistance.
Have a 200.13 paper jam error-check cartridge--???
Here's an article on
Receiving a Paper Jam Message When Using the Front-loading Manual Feeder on a Lexmark E250d/350d/352dn/450dn. Click on this link: http://bit.ly/cWZVZo. Read thoroughly, you might get some tips on how to avert this problem in the future. If problem continues, I suggest you contact Lexmark technical support to further investigate the problem.
E450dn get's a paper jam any time two or more
This is a possible pick tire issue. Try to reverse the tires, turning it inside out. Fan the paper and adjust the tray guide. If that doesn't help, printer will probably require service. I suggest you contact Lexmark technical support or your authorized service provider. Thanks.
931.01error codes
re-seat all connections from printhead to controller card and all connections at the printhead as well this is a "hard" failure of the printhead . it is slightly possible it could be a bad connection . but it is probably the printhead itself which is bad ...
Error 950.01 NVRAM Missmatch
Have you recently tried adding to or replacing the internal rem modules? If not they could have developed a fault. Try removing the and rebooting the printer see if that resolves the issue. I have also see this happen with a faulty daughter board which the ram plugs in to on a hp printer
How to cancel prints
go into control panel or where ever you go and open printers and hardware. choose the printer, in the menu left topside. click on file or edit one of the choices has the cancel all documents. at least this is the only way I've been able to. good luck
