I refer you to a Xerox support page (your model is WC7245)
http://www.support.xerox.com/support/workcentre-7228-7235-7245/support/engb.html
6.ovember.2015
SOURCE: xerox error code u1-1 main motor fault
You will need to replace the main drive motor assembly.
That stepper motor is a common fail item.
You have to remove the rear cover, the MFSYS and MCU board assembly to access that motor.
SOURCE: XEROX WORKCENTRE 5222/5225/5230 A FAULT OR
010-150, 155 Too much or not enough paper in duplex tray 10-300 Fuser thermistor 10-302 Low fuser temperature 010-304 Bad fuser temp 10-308 High fuser temperature or open thermistor 010-310 High fuser temperature 010-312 Fuser not up to temperature after energy save 010-314 Fuser problem 010-320 Fuser web finished 010-330,327 335, 340 Exit switch, vertical sensor switch actuated when power is turned on
SOURCE: xerox 5225 fault code 010-320
that is a fuser overheat code suggest you have a techintion repair or replace the fuser
SOURCE: xerox phasor 8400 - fault 37,004,40:157517"
Hi I can gave you some error codes but this all I can do hope it be of help to you.
8,009.4x:CAP_FAULT_MP_NO_ CLUTCH_STALL:
33,001.4x - TM_DEV_FAULT_MPT_WIDTH_VALUE_TOO_LOW
1. Check the wiring and connectors from the front door to the I/O board.
2. Run the Test Tray 1 Width Sensors.
3. If the test fails replace the front door.
4. Replace the I/O board.
08.055.44:
37,008.44:
Run the Preheat Heater test, check the wiring. If test fails and no apparently problem is evident, replace the preheater.
05,002.42:
7,008.4x: PM_FAULT_HEADTILT_NOT_ ENGAGED
1. Try rebooting the printer.
2. Check for an obstruction or damage in the process gearbox.
3. Ensure the gears are correctly aligned and homed. If faulty replace the process gearbox
assembly.
4. Run the Tilt Axis Drive test to test the headtilt.
5. Run the Head Maintenance Wiper Clutch test. If the test fails, replace the wiper drive clutch.
6. Run the Wiper Axis Drive test.
7. Replace the exit assembly.
7,010.4x: PM_FAULT_HEADTILT_HOME_ERROR
1. Reboot the printer.
2. Verify the lock arms rotate correctly.
3. Check for spilled ink around the printhead.
4. Check the process motor gears for damage. Ensure the process gears are correctly aligned and homed.
5. Verify the process gear box, process shaft, and drive module shaft are at home position.
6. Verify the headtilt gear will engage, see the home positioning procedure on page. You can manually engage the headtilt gear.
7. Run the Tilt Axis Drive test.
8. Run the Process Motor test.
9. Run the Head Maintenance Clutch test, if the test fails replace the clutch.
10.Run Wiper Drive test. If this fails inspect the wiper drive system.
All The Best: Pineworks
