20 Most Recent
Xerox WorkCentre 7228 7235 7245 7328 7335 7345 Fuser Cartridge 008R13028 Questions & Answers
How do i reset my drum for xerox workcentre 7345
You can't reset the drums counter on the machine. The drum has what they call a CRUM on it. It's the micro chip on the drum frame. You can buy new CRUM's or use one that still has some life on it. Press the two plastic retainers to remove the CRUM.
Error 007-276 xerox
- Check that the paper size setting is correct
- Check the switch actuators on Tray 3, for wear or damage. Repair or replace as required
- Check the Tray 3 Paper Size Sensor for damage or incorrect mounting
Fault error
I install xerox new machine when turn on gives error code 123-333
How do I know my fuser is good or not?
If the toner rubs off the page after it comes out of the printer the fuser is bad. Fuser wires get very hot, so if the page isn't slightly warm, thats a good indicator of a worn fuser wire
