20 Most Recent Xerox DocuColor 3535 Copier Questions & Answers
Hi there i have a Xerox Dc 250 and i have a fault
The laser scanner is defective PN 062K20984
5/9/2022 12:12:45 PM • Xerox DocuColor... • Answered on May 09, 2022
2answers
Fault 127-210. Printer functional but can not connect to command Workstation.
i think it is the problem of Fiery installation
recently i am gone through the same
but i got some other code
u can try by installing fiery
3/17/2021 9:43:14 AM • Xerox DocuColor... • Answered on Mar 17, 2021
3answers
116-325 error code on docucolor
Hi the 116-325 error for the 3535 is a 24Volt communication error.
The 24V power supply 105E18641 is probably bad, or possibly some wires that connect them.
Whit
Item, Inc
11/7/2019 10:35:49 AM • Xerox DocuColor... • Answered on Nov 07, 2019
Xerox 242 fault code 042-326
foult code 093-317
9/13/2019 7:11:30 AM • Xerox DocuColor... • Answered on Sep 13, 2019
4answers
Erorr 010-348
008-164
008-900
7/29/2018 4:14:43 AM • Xerox DocuColor... • Answered on Jul 29, 2018
My dc 3535 machine problem ess pws softwer
  • hy hru ?
  • my 3535 machine problem for a i you give pws diagnostic tool version 3.10
12/8/2017 2:11:15 AM • Xerox DocuColor... • Answered on Dec 08, 2017
How do I recover the operating system after replacing a damaged disk?
unfortunately , unless you have the data saved on another hard drive , gig stick etc , it is all lost you will have to install a new operating system from a cd or download from the net everything that you view , save on a computer is all on the hard drive initially so when that drive fails --all is lost there are companies that can remove the disc from a failed hard drive and then recover the data but , the cost has to be considered as it is not cheap
8/21/2017 11:46:15 PM • Xerox DocuColor... • Answered on Aug 21, 2017
Xerox 5225 fault code 010-320
that is a fuser overheat code suggest you have a techintion repair or replace the fuser
6/18/2017 11:38:57 AM • Xerox DocuColor... • Answered on Jun 18, 2017
Transparecy issue
+24 VDC power is failed. Status Code 102-319 is displayed after 116-325 is displayed.
+24V LVPS is failed. Perform following:
Remove Rear Cover (REP 14.2).
Remove cover from +24V LVPS (PL 9.1).
Disconnect P502 on +24V LVPS (Figure 1).
Check that power is switched off. Measure resistance of fuse on +24V LVPS. Resistance is 1
ohm or less.
if no Replace +24V LVPS (PL 9.1).
if yes Switch on the power. Measure the AC voltage between the white and black wires in P2 on the
+24 VDC. 110 or 220 VAC is measured.
5/11/2017 6:15:23 PM • Xerox DocuColor... • Answered on May 11, 2017
2answers
A FAULT HAS OCCURRED SOME FEATURES MAY BE
is there any error code tell us otherwise u need to see through pws
3/10/2017 8:15:58 AM • Xerox DocuColor... • Answered on Mar 10, 2017
4answers
Error code 116-365 on dc
Solutions for Fault Code 116-365: Fatal Error of the SPL (Spooler / Spool Queue) is Displayed With a Power the Machine Off and On Message
> Power OFF the Printer, Wait 45 Seconds, Then Power ON
For more details of the problem, visit:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=397,E=0000000001527486692,K=5902,Sxi=6,Case=obj%2845960%29
Hope this solves your problem,
Thanks.
10/31/2016 3:23:50 PM • Xerox DocuColor... • Answered on Oct 31, 2016
I havew an error message on a xerox workcentre
Power recycle if doesn't work Reset all printer settings skype id :johnwalker800969
9/12/2016 5:36:31 PM • Xerox DocuColor... • Answered on Sep 12, 2016
Hello I have a problem with my xerox. The message is: waste dry ink full! What should I do?
replace the dry ink container take it out and clean out get in a technician to clean/ replace it
7/16/2016 3:28:34 AM • Xerox DocuColor... • Answered on Jul 16, 2016
Xerox Printer not starting, A fault has occurred. Fault Error 116-201
The problem description is: Fault Code 116-201: HDD Was Not Booted Due to an HDD Error Detected on Booting. Try this link first: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=387,E=0000000005750000208,K=9799,Sxi=3,Solution=obj(542) If this does not work. Unplug the machine from the wall while still on do not power down first. treat it like the power just went off in your building. While the machine is still off not plugged to the wall. Press the power button several times. This will erase any saved info on memory. Plug machine back on an try again. If it does it again you will need to replace your hard drive and that will take a service call.
12/10/2015 4:42:12 PM • Xerox DocuColor... • Answered on Dec 10, 2015
2answers
Xerox 5225 fault code 010-320???
If you have a Xerox WC5225 with Error Code 010-320, then you have a fuser problem. The fuser is the heated item which bonds the image, just before it exits the unit. The machine monitors the temperature sensors and heating elements on this part.
The fuser is sold as PN 126K24980. It is easy to replace yourself.
12/3/2015 8:02:40 AM • Xerox DocuColor... • Answered on Dec 03, 2015
257 questions posted
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
reset 2nd bias transfer roll xerox 7556
  • Office Equipment & Supplies
