Dear
Connect the telephone line to the LINE socket of the fax machine and a telephone receiver unit to the EXT socket of the fax machine.
To send a fax, put the document on the platen glass (face downward) or face upward in case of ADF.
press on hook dial, (here the dial tone on machines speaker)
dial the fax no. ( wait for call connection and here the fax Rx. tone)
press START.
To receive a fax two procedure can made, manual- lift a hand set of telephone receiver on incoming ring, here the TX tone(periodical beep tone) press * 9 * of the telephone receiver. In auto mode go to fax setup select ans. to ring or auto fax etc. to activate atuo reveive of fax.
Hope this may helpful.
Thanks.
SOURCE: black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
SOURCE: communication error
I can give you a general answer. If the other fax machine is an older model, it probably has a slower baud rate. You probably have an option to slow your machine down. It goes thru a process to setup a tx speed, if it is not satisfied with the clarity of the line, it will timeout, hence your error. I would slow it down in increments until you get a reliable connection. If it only happens to one place, there is a possibility of a compatibility problem, which also can be solved, but would require service modes to do.
SOURCE: How to set Ans/Fax receiving mode of SCX-4521F?
Try setting the receive mode to FAX/ANS. If you want the fax not to pickup before a phone call comes in, you should set the number of fax rings to a higher number, like "5" for instance. Set the answering machine rings less and the fax higher. The machine will usually record a message first and then detect a fax tone.
SOURCE: not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
SOURCE: Fax Machine Samsung Model SCX-4521F
Kindly update me Is it printing/Copying working properly.
This issue with printing part. Kindly clear memory. Check Cartridges.
