20 Most Recent Samsung SCX 4521F All-In-One Laser Printer Questions & Answers
2answers
Help !!!! Firmware updates
FLASH UPGRADE There are methods to update the Flash. (1) Local Machine • RCP (Remote Control Panel) mode This method is for Parallel Port or USB Port. Connect the PC and activate the RCP (Remote Control Panel) to upgrade the Firmware. < Method > How to Update Firmware using RCP 1. Connect PC and Printer with a Parallel Cable or a USB Cable. 2. Run the RCP utility and select Firmware Update. 3. Search for the Firmware file to be used to update the set using the Browse Icon. 4. Click the Update icon. The firmware file is transmitted to the Printer automatically and the printer is initialized when the download completes. 5. Click the Refresh icon and check that the updated version numbers are displayed.
12/31/2022 6:51:13 AM • Samsung SCX... • Answered on Dec 31, 2022
How do i scan to a pdf and save on my pc
  • Scan it as a jpeg or whatever it is scanning as. then you can open the scanned image and
    save as a pdf
  • 2
    Turn on your samsung all-in-one device. Put your document that you want to scan face
    down on the tray of the samsung all-in-one.
    Open your samsung device manager on your personal computer or your Mac. Choose
    the "Scan" function. This will be slightly different depending on whether you are on a PC
    or a Mac andwhat samsung all-in-one model you have.
    Hit the "Scan" button on your samsung all-in-one or the "New Scan" button in the top left
    corner of the software on your computer.
    Click the drop-down menu at the bottom right of the scan window, below the image. Choose
    the "PDF File" option. Hit the "Accept" button. A dialog box that allows you to save your PDF
    in a location of your choice will appear.
    5
    Type a name for the PDF in the "Save As" field. Choose a place for it on your computer with
    the drop-dowm menu. Click the "Save" button. Your scanner will then scan the PDF and save
    it.
9/28/2022 7:30:51 AM • Samsung SCX... • Answered on Sep 28, 2022
My printer SCX4521F is givening error of front or rear cover open what can i do for it
hi find link for samsung printer http://www.samsungsetup.com/ts/manual/Samsung%20M288x%20Series/English/manual/CEGEGGFB.htm
2/3/2022 6:25:09 PM • Samsung SCX... • Answered on Feb 03, 2022
2answers
My samsung printer is not picking up the sheets of
It could be a dirty pickup roller in printer. Found following advice from Samsung:
Printer will not feed the paper depends on following possibility.
  • Paper Type:
    • If surface of the paper is too smooth, pick-up roller will not feed the paper.
    • In such case, try with different type of paper.
  • Pick-up Roller:
    • If the rubber roller is worn out, it will not feed the paper from the tray. There is not enough friction to feed the paper.
    • Pull the paper tray out and clean the rubber roller.
11/15/2021 6:02:37 AM • Samsung SCX... • Answered on Nov 15, 2021
10answers
Printer/Paper Jam Brother MFC
41093dd.jpgWell I fixed it!!! Here's what I did. You see this picture of the cover opened? Where the arrow's pointing is the home position of the printer head. Under there I found a scrap piece of paper! Here's exactly what I did. When I got home I decided to plug it in to see if it would work, but it made the same noise and showed the same error message as before. I opened the cover as shown above. This resets it, and it says "close cover". I closed it, and AS it started to go through its routine I OPENED IT again, and I could see the printer head moving back and forth. At this point I used a flashlight to see where the home position of the Head was, and that's where I found the scrap of paper!
I unplugged it for safety and was able to remove the scrap with my fingers.
By your descriptions, referring to the other users, you just might have the same problem.
11/6/2021 3:50:41 PM • Samsung SCX... • Answered on Nov 06, 2021
15answers
Samsung scx-4521f fax memory received but never print out.
In 3 second make combination on you Samsung 4521F 'Menu'-#-1-9-3-4. You will enter in tech menu. Select 'toner'-new toner-yes. You will receive faxes. It really works.
11/6/2021 3:49:52 PM • Samsung SCX... • Answered on Nov 06, 2021
11answers
Samsung SCX-4521 "Paper Jam 2" won't clear
I had this problem too. For me the answer turned out to be the paper sensor in the back part of the machine, behind the little back door just under the top part of the machine. This sensor hangs down from a thin rod that runs across the width of the machine, and is held in place by a small spring that encircles the same rod that supports the finger. The finger had apparently gotten moved so the spring was dislodged from its proper place. I was able to rotate it around the rod with my finger & get the spring moved back to where it should be. This seems to have cleared the problem--I'm keeping my fingers crossed.
11/6/2021 3:47:04 PM • Samsung SCX... • Answered on Nov 06, 2021
2answers
Error out of range
dear Irfan khan, pls. enter the date format as MM/DD/YYYY suppose it as 20th June 2014 enter as 06202014 ok.... if it not solved pls. write me....
5/27/2021 12:29:16 PM • Samsung SCX... • Answered on May 27, 2021
4answers
Lsu error on samsung scx4521f, what can i do
ON SCREEN SHOW MESSAGE - "LSU ERROR"
11/27/2019 1:03:15 AM • Samsung SCX... • Answered on Nov 27, 2019
3answers
I cant scan to a mac Book pro From a samsung SCX-4...
not solovation
11/12/2019 2:58:55 AM • Samsung SCX... • Answered on Nov 12, 2019
I want samsung smarthru scanner
go to samsung web page and write your printer model in the little window then download the newest drivers from the download page, you will need 1. driver for the printer, 2. driver for the scanner, 3. driver for the fax and last samsung Dr. Printer
11/7/2019 12:58:23 AM • Samsung SCX... • Answered on Nov 07, 2019
Sammi James - expert spammer is back again - at least no fake phone numbers! I am trying to scan on my samsung all in one laser
uninstall your samsung scx-4521 all drivers from your PC and reinstall with a samsung OEM cd .
then presit the same pls. install the TEAMVIEWER software and send me a mail to me.
11/5/2019 12:21:52 AM • Samsung SCX... • Answered on Nov 05, 2019
Setup
Go to Control panel>>Installed printers and delete your samsung from installed printer list.
After deleting, unplug printer cable, restart computer and reinstall the software from disk.
If you do not have disk you can download software and manual from here: download center SAMSUNG
11/4/2019 1:20:30 AM • Samsung SCX... • Answered on Nov 04, 2019
I wnt 2 install samsung
Go to the Samsung support website & download the correct driver for your printer & operating system.
http://www.samsung.com/mea_en/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=06010300&prd_mdl_cd=&prd_mdl_name=SCX-4521F
10/27/2019 1:17:27 PM • Samsung SCX... • Answered on Oct 27, 2019
I have a mac os x version 10.6.6, and a samsung
Here are the drivers:
Printer: http://downloadcenter.samsung.com/content/DR/200912/20091217112644875/SCX-4x21.zip
Scanner: http://downloadcenter.samsung.com/content/DR/200912/20091217112644875/Samsung_SCX-4x21_Scanner.zip
I hope you got the answer. :)
10/22/2019 12:16:22 AM • Samsung SCX... • Answered on Oct 22, 2019
I HAVE INSTALLED WINDOWS 7
Hi
www.samsung.co.za or www.samsung.com and download the driver or the universal driver that works on most of the samsung printers.
Good Luck!
9/26/2019 1:17:19 AM • Samsung SCX... • Answered on Sep 26, 2019
3answers
Samsung printer scx-4521f need smarthru4 scanner
need a reliable site to download smarthru4 scanner software for Samsung printer scx-4521f
9/20/2019 2:57:02 AM • Samsung SCX... • Answered on Sep 20, 2019
Samsung SCX 4521F All-In-One Laser Printer Logo
1,248 questions posted
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
SCX Samsung
  • SCX Samsung
Most Popular Question
lsu error samsung scx4521f
  • Office Equipment & Supplies
