20 Most Recent
Samsung SCX 4200 All-In-One Laser Printer Questions & Answers
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Paper jam
After the fuser, problably near the exit rollers, there is going to be a switch/sensor, that has a problem. It could be hung up, out of position, ect, but you have a typical exit sensor problem.
My samsung tonarscx 4200 is one said lait print
Good day Sir,
Your toner cartridge has run out. Replace toner cartridge with a new one. To purchase Samsung-authorized cartridges, contact you local Samsung dealer or retailer where you purchase your machine. or visit www.samsungprinter.com and select your country/region for information for technical support.
Thank you.
Toner empty error
toner empty replace toner with without reset chip
i want window file printer start without reset chip run printer
i am all ready use ml1640,ml2245 printer file use
thanks
vijay
When replace SAMSUNG SCX-4200 toner,
if the cartrige is not from samsung then there are some informations missing on the cratrige chip, you can try to purchase this chip from the shop you bought the cartrige and tell them about your problem!
How can I reset chip
I am presuming you want to reset all the systems settings to the factory defaults. Try this:
Clearing memory
You can selectively clear information stored in your machine's memory.
1 Press Menu until Maintenance appears on the top line of the display.
2 Press the scroll button ( or ) until Clear Settings appears and press OK.
3 Press the scroll button ( or ) to select the item you want to clear.
• Paper Setting: Resets all of the Paper Setting options to the factory default.
• Copy Setup: Resets all of the Copy Setup options to the factory default.
• All Settings: Resets all of your settings to the factory default.
• Machine Setup: Resets all of the system settings, such as the display language and save
mode, to the factory default.
4 Press OK to confirm clearing. The selected setting is cleared.
5 Repeat steps 3 through 4 to clear another setting.
6 Press Stop/Clear to return to Standby mode.
Pickup roller fails to load paper sometimes from
Pickup rollers suffer from several possible faults-
- Cheap paper can lose fibers that clog the roller reducing friction
- Rollers can harden, reducing their 'stickiness'
- The slightly roughened surface of the roller loses its roughness
Sometimes the roller will improve with cleaning but don't use alcohol since this will leach softeners from the roller so a mild detergent is better such as window cleaner and a fiber-free cloth; you don't want to worsen the problem.
Some mfr.s (HP for one) have produced short-lived rollers that required 'roughening' pads and a small program to drive the roller for seconds to minutes to restore the minute 'fingers' to the roller.
If a high-usage printer, you may have to replace the pickup roller and the labor involved varies greatly.
One 'quick and dirty' method that sometimes works is to reset the paper length to 'legal' (runs longer) and put a good quality paper sheet that has been wetted with window cleaner in the feed slot and allow the roller to rotate on that surface by holding the end of the sheet.
The printer will eventually error out with a 'misfeed' that may require resetting.
Allow it to dry again before trying to print.
Samsung ML-1640 LSU error
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
