SOURCE: Belkin N1 Wireless not STAYING connected
change channels to 1-6-or 11. Make sure you change all of them.
SOURCE: Downloads locks up - Belkin N1 Wireless Router
I had the same problem. My Belkin N1 Router was constantly dropping the WiFi connection (every few minutes). I tried several solutions I found on different forums:
Change the channel selection from Auto to a specific channel -- I tried all 13 channels, but no improvement.
Update the firmware to the latest (Beta) version -- still no improvement.
Finally I enabled "Protected Mode" and the connection seems fine now. Hope this helps, and good luck!
SOURCE: how do put the wireless
Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter, there should be an option there.
SOURCE: Belkin N1 F5D8231-4 V3000
are you running the Cisco VPN client from home, where this Belkin is your gateway and connecting to say your work?
If so, have a look in the settings of the Belkin to see if you can enable VPN Pass-through.
Try disabling some of the firewall functions on the belkin to isolate the issue and turn the rest back on.
If for some reason this model doesn't work even after the above, try changing the VPN client's connection settings,there are only two to choose from... (click modify on your connection entry, go to the Transport tab > then choose from:
IPSec over TCP and IPSec over UDP (port 10000)
SOURCE: No I'dont find that I
Go to this link http://en-us-support.belkin.com/app/product/detail/p/327
and download the new firmware
press the RESET button on the back of router for 30 SEC when ON it will reset and work fine later dont worry pls let me know if it helped
