The blinking is just an attention light so there's nothing to worry about that. Try adjusting your paper tray to the paper size you are about to use. Or try checking the duplexer panif its positioned properly. Hope this helps.
<span><span>Hewlett Packard Ink System Failure Error Fix (tested C6180) </span></span>
<ol>
<li><span><span>Press and hold the "*" key. </span></span></li>
<li><span><span>Press the "#" key and release both keys. Display should say "Enter Special Key Combo" </span></span></li>
<li><span><span>Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M </span></span></li>
<li><span><span>Press and release the right arrow button until the display says "System Configuration Menu". </span></span></li>
<li><span><span>Press and release the "OK" button.</span></span></li>
<li><span><span>Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", </span></span></li>
<li><span><span>Press and release the "OK" button. </span></span></li>
<li><span><span>Display should say "Hardware failure status: Clear. Press OK to clear". </span></span></li>
<li><span><span>Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". </span></span></li>
<li><span><span>Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. </span></span></li>
<li><span><span>Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.</span></span></li>
<li><span><span>Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer </span></span></li>
<li><span><span>Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. </span></span></li></ol><span><span>I hope this helps</span></span>
<span><span><br /></span></span>
<span><span>Regards GM</span></span>
<br />
Hi,<br />
<br />
<br />
Please perform the following steps and let me know the message that will be displayed on the printer.<br />
Press and hold the "*" key. <br />
Press the "#" key and release both keys. <br />
Display should say "Enter Special Key Combo" <br />
Press and release in sequence the "1", "2" and "3" buttons.<br />
Press and release the right arrow button until the display says "System Configuration Menu".<br />
Press and release the "OK" button.<br />
Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",<br />
Display should say "Hardware failure status: Clear. Press OK to clear".<br />
Press and release the "OK" Button. Message changes to "Hardware failure status Press Cancel to continue".<br />
THIS STAGE.<br />
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.<br />
printer<br />
printer will print out a Diagnostic Page.<br />
<br />
If I could be of further assistance, let me know. <br />
Thanks,<br />
<br />
LETMEFIXIT
If the printer is making noice as it is preparing to print but does not take paper, then it has broken gears inside. Disasembly takes a lot of time and the spare part is called "printer mechanics" which is the half of the printer.
It could be that the cover sensor is stuck or could also be due to the cartridges in the printer. Please follow the steps below on how to identify and fix the problem:
Remove the sheets of paper from the feeder.
Open the printer cover and remove the cartridges.
Close the printer cover.
Re-brick your printer by pulling out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
When the printer turns on, reinsert one cartridge first.
Close the printer cover and check for any errors.
Reinsert the other cartridge.
Replace whichever cartridge is causing the error to appear.
If no error appears, reload some sheets of paper and try to print a document again to verify that problem is fixed.
If the problem continues, please contact the Lexmark Technical Support Center for additional assistance.
The Paper Jam message may appear on the display if
the Brother machine is not feeding paper correctly, paper scraps stucked or the paper is not loaded properly in
the paper tray, the jam clear cover located in the back of the machine,
is not installed properly or the PE Actuator is missing or damaged.
Please visit the link provided below to resolve the issue step by step :
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.get more help and information for hp printer support hope this helps you.
The paper trays are empty or overloaded.The paper is curledThe print side, or shiny side, of the paper is not loaded in the input tray face down.The paper might not be engaged with the feed rollers.The paper-width guide is pressed against the paper stack too tightly.The paper tray is not completely inserted into the product.The paper settings in the print driver do not match the paper loaded in the paper tray.The rubber paper-feed rollers are coated with dust.
My microsoft Word displays the message printer out of paper
