Try the following steps:
1. Turn off printer. 2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color. 3. let go button Resume/Cancel, continuing to retain POWER. 4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons. 5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!! 6. turn off printer by button POWER.
Regarding your recent inquiry about the poor black print quality (Canon PG-225 PGBK ink cartridge) & lack of overall printing performance with your Canon MX882 printer, it sounds like your PRINTHEAD is either clogged (from dried ink) or has reached END-OF-LIFE, to help determine which please perform the following steps (if you have already performed a step, please continue to the next step in the order shown):
Canon Cartridge Troubleshooting: http://inkjet411.com/?page_id=1537
1.Go into the printer's maintenance/tools menu and print a print quality test (i.e. heading cleaning, nozzle test or similar) to help identify which color (of number of colors) is impacted.
NOTE: To help determine which color has run out, use the following suggestions in sequence until you are able to identify the empty color: 1) Generate a Print Quality Test Page from your printer control panel; a faded color band indicates empty. 2) To distinguish between a black and photo black cartridge, print a text document and/or a photo. Faded black in a text document indicates the black cartridge is empty; faded black in a photo indicates the photo black cartridge is empty. 3) To distinguish between cyan, yellow, and magenta click here: http://inkjet411.com/?page_id=146 A faded or missing color band indicates empty.
2.At the printer's control panel under the 'Maintenance' or 'Tools' menu, activate a 'CLEANING' or 'HEAD CLEANING' to prime the ink system. Then Run the Inkjet411 'Ink Recovery Test Print' from our Test Prints page to verify all colors are firing properly (all printers also provide some form of a Self Test page): http://inkjet411.com/?page_id=146
3.Check your user's manual to see if there are any procedures on cleaning the service station/capping station assembly (this is where the carriage/cartridges 'park' when not in use). A dirty service station can cause all kinds of improper color output problems (assuming the printhead is working correctly of course). NOTE: May not be applicable for your model depending on the printer design.
4.The Ink Absorber, if applicable depending on print model, may also be full which could also cause printing related issues (typically an error code will be displayed when the ink absorber is full)...here is a customer/yahoo response on this particular issue: http://answers.yahoo.com/question/index?qid=20130523085451AAE1TqW
5.Refer to our print quality support page to ensure other variables are not causing the issue such as printer driver settings or operating system device conflict, etc: http://inkjet411.com/?page_id=1432
6.If this does not remedy the problem, then one or more of the ink ports may be dry within the PRINTHEAD assembly (the ink cartridges physically connect to this electronic assembly). We suggest you either remove the printhead and perform a hot water flush for 2 minutes (in a sink) or using an eye-dropper, or similar, drip 5-10 milliliters (i.e. 1-2 teaspoons) of distilled water into the respective color ink port to help saturate the foam. http://inkjet411.com/?page_id=2804
7.Reinstall ink cartridges and retest.
Inkjet411 Suggested PRINTHEAD Cleaning Procedures:
Canon Printhead Warm-Water Flush Procedure: http://inkjet411.com/?page_id=28043rd party PRINTHEAD CLEANING solutions (for additional reference only):
http://www.youtube.com/watch?v=FL8QaFVwsEs(Canon)
http://www.youtube.com/watch?v=ZheZf-vdho8 (Canon
8.If the problem persists, then you may have a damaged PRINTHEAD (worst case scenario), unrelated to the refilled cartridges. The printhead is a separate electronic assembly (which the cartridges are installed into) and is responsible for firing the ink drops onto the paper. Over time and based on usage this assembly will eventually fail (typically lasts ~4,000 to 5000 printed pages on avg). Refer to video on how the PRINTHEAD functions: http://inkjet411.com/?page_id=2054
PRINHEAD TECHNICAL NOTES:
IIT (individual ink tank-based) printer models have an electronic PRINTHEAD within the base of the carriage assembly (responsible for pulling ink from the 4, 5 or 6 ink cartridges and then firing the ink droplets onto the paper) - these will eventually fail depending on print usage type and printer duty cycle (i.e. rated for approximately 10,000 printed pages over life, but the consumer average is typically closer ~4,000-5,000 thruput pages). The printhead is replaceable and can be ordered directly from the manufacturer or www.Amazon.com . For information on how the PRINTHEAD functions, please watch the following video: http://inkjet411.com/?page_id=2054
Typically the printhead should not reach it's end-of-life until after a minimum of 8 or more complete sets of cartridge changes. While some printheads may last 10,000+ pages others may only last 2000 pages, actual results will vary. The printhead will eventually fail in time due to an internal micro-electronics failure, due to the following leading factors: general customer print usage and printer care, printer duty cycle (i.e. # pages printed per month), printing frequency (i.e. time between each print job), print mode (i.e. draft vs. normal) and content printed (i.e. photos vs plain pages) and color mode (black and white only vs. color/greyscale printing).
Paper types used (i.e. plain paper, photo papers & matte/heavy bond papers) and paper edge curl (i.e. duration in printer and/or exposure to low relative humidity) can also quickly lead to premature printhead failures due to physical 'head strikes' of the paper edges making repeated contact with the printhead nozzle plate surfaces.
CAUTION: the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors and permanent PRINTHEAD damage. We do NOT suggest refilling these types of ink cartridges.....refilling of original/genuine ink cartridges is only suggested!
Canon 225/226 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=t1QDEDRZapY
For USA store ink refill locations and details on ink refill pricing:
Costco USA Ink Refill Service (all 453+ stores): http://www.costcoinkjetrefill.com
Fry's Electronics Ink Refill Service (all 34 stores): http://www.frys.com/ads/page51
Micro Center Ink Refill Service: http://www.microcenter.com/site/content/refill-service.aspx
Customers who have questions regarding the use of refilled ink cartridges can visit http://www.inkjet411.com or contact us directly at [email protected]
-Thank you
I tried all the reset codes and so forth you might find on other
otherwise useful forums, and i have successfully modded 5 of these to
print on DVDs, but this "operator error" and five yellow flashing lights
was a tough nut to crack. I was about to give up and toss it when I
tried one more thing and it works!
With the cartridges removed and the printhead carrier in the central
position, press the empty printhead's back gently but firmly about a
dozen times back against the printhead carrier, pushing it in toward the
rear of the printer. I think this may help improve a bad contact
between the half a dozen or so rows of little metal contacts on the
printhead and their corresponding protruding little metal pins on the
printhead carrier. It feels a little spongy (you can feel some give) as
you push it in toward the rear of the printer and it gently springs back
forward.
This solved it for me. I thought I'd share my idea and successful solution, and I hope it helps you, too.
Don't believe the stereotype about blondes being dumb. Here is a link for software and manuals for your printer. These are for WinXP. If you need the driver it is listed under software. Under guides and manuals you will find three including a quick start, setup and full manual. I advise downloading all three. YES, they have pictures. If you need Vista just add a comment and I'll come right back and show you where to find it although you can find it at same site. Good luck blondie. If you need more help just ask. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10238#DownloadDetailAct
Unplug the unit and check it at another outlet, preferably on another circuit. This is just to be sure the problem is at the power supply not an overloaded circuit.
If it doesn't turn on, then the unit is in need of repair or replacement. If the printer is still under warranty, contact Canon at 1-800-OK-CANON (toll free) from 10 AM to 10 PM M-F (except holidays). Otherwise decide if the unit is worth the charges for diagnosis and repair. The diagnosis will probably start at ~$50 that will be included in the cost of the repair if you decide to continue.
I have been using the Canon MP180 PIXMA for almost three years now without a hitch until I received a paper jam warning which I could not resolve. I Googled "Canon PIXMA paper jam" today and landed on this site. I turned the printer upside-down and shook vigorously. Out popped a small pebble-like bit of concrete which somehow found it's way into my printer. I guess our hardwood floor installation on the floor above had shaken up some old plaster and concrete bits that had lodged in our drop-down ceiling from our 3rd floor bathroom renovation last year and this little ****** came through an opening in our rec-room (where the computer and printer are) drop-down ceiling. A very strange sequence of events, that I would not have suspected, but happy to say that your advice here did the trick and the printer is a tough and trustworthy little printer afterall!
Thank you.
Dan in Canada
Maybe. Sounds like the print head is fubar and Canon charges a fortune for them; it is cheaper to get a new printer in that case after checking it out.
Before shopping you might want to try a hard reset of the printer and reinstalling the software after uninstalling the prior software. If still bogus then .....................
Print head is fubar and for the cost that Canon will hit you with for a new print head you really have no alternative - new printer is cheaper than print head and also comes with a warranty.
If you unplug a printer that is performing a firmware update then that ruins the logic board. However you do not say why the update was being performed. had you initiated the update? or did the machine start to do this of its own accord? Anyway its too late now. A new logic board is required and it has to be done by a Canon engineer as his has the software to reload its programming. This is well out of the scope of a user repair. Sorry.
I found a solution to the Black printing problem :)
Under Printing Preferences: Set your Media Type to Photo Paper Pro.
We used edible ink cartridges and printed onto icing sugar paper. Same old... Just one day it refused to print black. In order to continue our small business, I degraded the color until I printed gray and not black.
Tonight, I browsed for the problem and came across this :)
Canon IP3000 INK counter reset
Can gave it a go may work
1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal..
