ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Defiantly a main drive issue, slipping belt can make the noise you described, sometimes the pulley gets tight or the tensioner binds causing the belt to slip
In my experience, it was the registration roller causing the grinding noise. See http://my.brainshark.com/Phaser-6300-6350-6360-Grinding-Noise-795590408 for troubleshooting video.
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Make sure that the paper guides in your paper tray are not holding the paper too tight against the front of the tray, there should be about 1/16 inch play so that the paper can be lifted to the roller easily. Also take out your toner and drum and turn it on, if the grinding noise is gone you may need a new toner, some refilled toners are too tight to turn properly.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Also open the back cover of the printer if this model has one.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
see alternative if the problem is still not solved.
alternative : Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
I took mine apart from the back and put it back together and it worked. It is probably due to moving it and the bottom paper tray alignment gets out of whack. I inspected all of the gear train and didn't find any worn or missing teeth. I suspect a paper jam started it and the user turned the printer around to open the back door. Since the handles are on the printer the tray doesn't move with it which allows it to separate and possibly jam a pickup drive gear.
