20 Most Recent Brother MFC-9420CN All-In-One Laser Printer Questions & Answers
Error message: No TR Roller Install the transfer roller
Hi
This error has already been noticed by Brother and they have a fix for this issue. This message will appear on your Brother machine if the ground clip is not present on the Transfer Roller Assembly. The clip can become dislodged due to a paper jam or removal of the Transfer Roller assembly.
To check the fix from Brother visit this link--
Brother TR Roller Install error removal Pictures
Please get back to me if you have any queries.
Daniel Scott
2/11/2021 6:53:23 PM • Brother... • Answered on Feb 11, 2021
2answers
Hi, I have a black line that runs from top to
the blcak line that runs from top to bottom is due to a dirty misaligned print head...do a full printer maintenance on your printer/scanner . Once the heads and rollers get clean and the printer is aligned, it should get rid of any black streaks or lines. I own a Brother Printer/scanner and it did the same thing to me, as soon as I ran maintenance on it..it fixed the black straks and lines I had on my prints.
8/23/2019 5:08:27 AM • Brother... • Answered on Aug 23, 2019
2answers
Black line 1cm in from margin when printing
this is a catridge problem so pls replace your printer catridge.
8/23/2019 4:55:24 AM • Brother... • Answered on Aug 23, 2019
Brother MFC 9420cn "unable to print see troubleshooting...users guide"
ctstore,
Your unit requires replacement of its maintenance kit. You will not be able to do this by yourself unless your are a technician, which I assume you are not. The cost for this repair will not be cheap, you are going to be up for over $500 and you need to do it through a brother warranty service centre.
Gremlin11
2/12/2019 8:04:41 PM • Brother... • Answered on Feb 12, 2019
Mfc-9420cn will not display anything on the lcd
need service or replace LCD
9/10/2016 6:08:00 PM • Brother... • Answered on Sep 10, 2016
Left to right on the lower half of the sheet.
Lift the scanner cover and next to the scanner glass is smaller glass. Make sure there are not any pieces of paper, ink pen marks or dust on that glass. It will leave a black line while copying and scanning. You may need to get a flash light and shine it at different angles to see a pen or pencil mark on the glass.
4/22/2016 7:35:53 PM • Brother... • Answered on Apr 22, 2016
NO OPC BELT on MFC-9420cn
The opc sensor is not sensing the belt. Open the front cover and remove all the toner trays. You will see the green OPC and the sensor is located in the left upper corner. Also open the top cover and remove the OPC. Clean the sensor with a soft bristle brush. Also make sure the OPC left side is free of toner deposits. This may incorrectly trigger the OPC position sensor. Hope this helps. no-opc-belt-mfc-9420cn-grua3dqrdj4m0mpexfswu5ak-2-3.jpg
11/24/2015 6:03:26 AM • Brother... • Answered on Nov 24, 2015
2answers
Machine error 28
Well it's a low temp error for the fusing assembly. Sounds like you already had it in Maintenance Mode. Sometimes those errors can only be cleared out by entering maintenance mode and pressing 9,9 to exit out. Should then start the normal warm up procedure. If the problem continues then reseat the fuser or take it out and measure for continuity across the lamp and thermostat. The service manual also recommends checking the line voltage. Basically make sure it's plugged straight into a wall outlet and no other large power sources on the same circuit. Example, another copier or this time of the year a small space heater. Maintenance Mode enterance Press Menu/Set and Black start button and Up arrow 4 times. Machine will read Maintenance on the display if done correctly. Press 9,9 to exit of the mode and the machine will attempt to restart normally. OR In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :Brother Printer Support
9/9/2015 6:45:39 PM • Brother... • Answered on Sep 09, 2015
Mine says that I need to install it. Never took it out. Reset does not work. Suggestions?
Most probably faulty Belt or Motherboard
1/21/2015 4:40:04 PM • Brother... • Answered on Jan 21, 2015
I have colored smears on left side of all my printed pages with my Brother MFC-9420 CN. What causes this?
It's not unusual for paper to hit the bottom of the print head, especially if the paper is bent. This can cause smearing. If you have pets, you can check for pet fur in the printer, or other foreign material inside that can also cause smearing.
9/11/2014 8:58:15 PM • Brother... • Answered on Sep 11, 2014
0answers
0answers
Brother MFC-9420CN All-In-One Laser Printer Logo
287 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
machine error 28
  • Office Equipment & Supplies
