20 Most Recent
Brother MFC-8460N All-In-One Printer Questions & Answers
When I try to scan a document on the MFC 8460N
Welcome to FixYa!
Try to print a document. If it does not print, do the following:
1. Unplug the power cable of the printer while it is ON. (Hard reset)
2. Disconnect the printer cable from your computer.
3. Shutdown the computer.
4.Turn the computer back ON after 30 second.
5. Connect back the printer cable to the computer.
6. Plug the power cable of the printer and turn it on.
7. Try to print a document first. If it prints, proceed to scanning.
What we are doing is that we are trying to see first if the printer is establishing connection with your computer. Make sure that the cables are properly connected.
Keep me posted for the developments.
Thank you for using FixYa.
Jas
3/2/2021 5:27:58 AM •
Brother...
Answered
on Mar 02, 2021
How do I replace PF kit1 Brother MFC-8460n
The paper feed kit is the pick up rollers and the transfer rollers. You can thake those out clean them and replace them, but unless you are actually having paper feed issues usually just clean the paper tray feed rollers with alcohol and reset the paper feed kit counter if needed.
3/2/2021 5:27:31 AM •
Brother...
Answered
on Mar 02, 2021
Brothers mfc-440cn - unable to clean 51
The error indicates multiple problems, and needs to be serviced by a ASC Brother Center. Go to brother.com and go to support and then service center then enter your zip code or you can ship to us since we are a ASC Center for Brother.
2/26/2019 6:39:09 AM •
Brother...
Answered
on Feb 26, 2019
Brother 8460n Fuser Unit
Hit in sequence Menu,*,2,8,6,4
This will put it in maint. mode.
Press 88
That is parts counter reset, scroll down and hit ok on the part you want to reset the counter. :)
11/6/2018 4:45:32 AM •
Brother...
Answered
on Nov 06, 2018
I have a Brother MFC8460n
did you also enable overseas mode? https://www.voipmechanic.com/voip-fax-settings-brother.htm
10/3/2017 2:20:10 PM •
Brother...
Answered
on Oct 03, 2017
Brother MFC8460N was working great and now today
Try re-installing the scanner software - if you don't have the disc you can download it. The scanner is a very delicate mechanism so is easily damaged - if the software fix don't work maybe it is kaput
10/3/2017 8:30:31 AM •
Brother...
Answered
on Oct 03, 2017
